How to change pin settings of x-cube-mcsdk ver.6.2.1
RIG
Please refer to the attached file.
I want to change the PB3 pin of Encoder B and use SWO.
Please tell me how to change the pin.
浚钱.1
You can modify the configuration file described in your JSON language when creating a new project.
Thank you for answering.
Do you have detailed instructions?
Billy OWEN
Hi @RIG
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Billy
