How can I do to count motor steps with Input Capture Direct Mode with DMA?
‎2020-09-01 4:10 PM
I want to count the steps that the motor takes with DMA and when it reaches a certain number of steps, turn off the PWM timer. How do I read the incoming pulses?
- Labels:
STM32 Motor Control
‎2020-09-01 4:45 PM
I would set up the timer in external clock mode and use the signal as the clock source.
I don't think DMA is needed here.
‎2020-09-01 4:45 PM
‎2020-09-01 6:49 PM
Ok TDK, i will try this configuration. Thanks you!!!
