2021-11-28 10:03 PM
2021-12-20 11:01 PM
Dear @Community member
Sorry for the late answer.
Do you have still this problem to solve?
And just in case, if not, do not hesitate to share the final solution you found. Thanks by advance.
Best regards
2021-12-20 11:26 PM
Dear @Laurent Ca... ,
Yes, I have the issue. In workbench, the PWM frequency is 30k. However in the second picture, first updated PWM value is 20k. Hence the motor is only running at 20k. Not varying between 10k to 40k
