Hello, World! I am using the NUCLEO F446RE and X-NUCLEO-IHM08M1 - 3 ch to create a driver for a permanent magnet motor. Error during project generation! I need help!
AndrewSibiryack
in the attachment to the letter I attach three files, two of which are log files and one with screenshots
cedric H
Hello @AndrewSibiryack​ ,
Could you try to open the IOC file generated in your project folder directly by cubeMX tool and try to generate from there.
Let me know if it does the job.
Cedric
AndrewSibiryack
Hi!
Thanks! Everything worked out!
Now there is an error when compiling to KEIL. it is not clear where the value of SPEED_LOOP_FREQUENCY_HZ is defined.
