Can I use the TrueStudio for the P-NUCLEO-IHM001 board?
Jace
15 REPLIES 15
That's the right version of MCSDK, Thanks!
Can you please check your IDE version as well?
CubeIDE is 1.3.0
Thanks,
Indeed we will start investigation => it does not explain the problem
BTrem.1
Senior II
I have been able to build and run projects in the SDK_5.4.3 directory using the Keil Tool chain (MDK-ARM) though on some I needed to optimize size not time, to keep below the 32k limit on the Lite version.
Laurent Ca...
Lead II
Dear @Jace​ , dear @BTrem.1​
Do you have still this problem to solve?
And just in case, if not, do not hesitate to share the final solution you found.
Best regards
Laurent Ca...
I ended up using Keil uVision 5.30, MDK-Arm Essential version. Sometimes I also use STM32CubeIDE.
Brian
