X-CUBE-USB-PD VDM issue on FUSB307BGEVB
2019-10-24 9:24 PM
Act as the DFP. I request the PE to send SOP identify request to the UFP after PE received the data it didn't fire the callback function. (I set the breakpoint at fusb305_tcpc_get_message and i see the data received from the DFP is correct.)
But
- when i request the PE to send SOP SVID request to the DFP it did fire the callback function.
- when i request the PE to send SOP' identify request to the cable it did fire the callback function.
I'm not sure if i set the configuration correct or there is any problem in the usb pd library.
Thanks.
John
- Labels:
USB-PD
2019-11-12 2:27 AM
Dear @Yohann M.
I found the same issue in :USBPDCORE_PD2_FULL_CM0_wc32 and :USBPDCORE_PD3_FULL_CM0_wc32.
Could you please upload the fixed version of them.
And i also want to report the issue when i test the MB1303_Demo_DRP_CLI.
- If i want to enable the Vconn support not only define the _VCONN_SUPPORT but also _APPLI_VCONN_SUPPORT.
- I set the sop and sop_1 support in the usbpd_dpm_conf.h but when PE stack calls the USBPD_PHY_Init it just sets the SupportedSOP to sop.
Thanks.
BR
John.
2019-11-12 5:33 AM
Dear @John886
Please find all the libs generated with VDM patch.
For the 2nd question, I would prefer keeping the other thread already opened by you :
Regards,
Yohann
Note: For your information, we posted an update of X-CUBE-USBPD under github (V3.1.0):
2019-11-20 7:04 PM
Hi Yohann
Thanks for your help :)
BR
John.
2020-04-17 6:44 AM
Dear @John886
=> https://github.com/STMicroelectronics/x-cube-usb-pd
Regards,
Yohann
- « Previous
- 1
- 2
- Next »
