Using HAL NAND
‎2024-09-12 11:35 AM - last edited on ‎2024-09-12 11:43 AM by mƎALLEm
Good afternoon.
I am configuring a NAND memory using FMC on the STM32H7. I am dealing with the following scenario: HCLK = 80 MHz (to match the example in AN4761) and a NAND memory SkyHigh Memory S34ML01G1 Following all the calculations specified in AN4761, I am encountering an error where the last byte fails on some pages. When a read is performed more than once, the byte is corrected, but there is this inconsistency. Where could the error be?
- Labels:
STM32Cube MCU Packages
‎2024-09-13 1:28 AM
Hello @neemiasims,
Which STM32H7 are you using?
Please try to configure the NAND memory area as Strongly-Ordered using MPU, for that I recommend you to take a look at STM32 MPU tips - 1 MPU usage in STM32 with ARM Cortex M7.
Thank you.
Kaouthar
‎2024-09-13 1:28 AM
Hello @neemiasims,
Thank you.
Kaouthar
‎2024-09-13 4:22 AM
I am using the STM32H723ZGTx. I am not working with MPU; it was disabled in the 'CORTEX_M7'. I will look into using it to see if it solves the problem. One detail: If I add a 1ms delay after each read and write, the last byte works perfectly, but this makes the memory operation very slow.
