Updating our own bootloader when the read out protection is set. Is it possible somhow to clear the Read out protection and then write a new bootloader from eiter our main firmware or maby a application in ram?
‎2019-10-22 3:39 AM
The processor is a STM32F107RB. We dont have the possiblilty to update it via jtag.
Bootloader
STM32F1 Series
‎2019-10-22 6:08 AM
It’s possible but not easy. You could run your code from SRAM to erase the flash and write a new bootloader. Make sure the code you run in SRAM doesn't try to access any variables in flash. The limited amount of SRAM could be an issue.
‎2019-10-22 6:27 AM
It have just made a test and write the flash from sram, but it seems that i'm not able to write to the flash after i clear the read out protection. i just end up with a empty flash then.
‎2019-10-22 6:40 AM
‎2019-10-22 6:55 AM
Yes then it works
‎2019-10-22 8:25 AM
Changing the readout protection level takes effect at the next system reset. So you have to load the reflashing code complete with vector table (a minimalist one would do if not using interrupts) in SRAM, and pull both BOOT0 and BOOT1 high while resetting the system to have it started.
‎2019-10-23 12:14 AM
I have no posibility to manipulate the bootpins so i might not have any posibilitiese to change the bootloader then.
