Trouble to implement Azure example for board B-L4S5I-IOT01A to Stm32CubeIDE
‎2022-03-25 2:33 AM
Recently I have been trying to implement an example from ST where data is sent telemetry to Azure. The problem is that Stm32CubeIDE did not generate Netxduo / addons / azure_iot. I am trying to manually add this folder but there are a lot of errors regarding includes and in the example I do not see these folders and files, although in some files they have #include "nx_azure_iot_json_reader.h" which is part of azure-sdk-for-c. If you have any ideas where you need to select somewhere in Stm32CubeIDE to generate this file, please give me advice.
Link to example: https://github.com/azure-rtos/getting-started/tree/master/STMicroelectronics/B-L4S5I-IOT01A
Stm32CubeIDE version: 1.8
AzureRTOS
STM32CubeIDE
STM32L4 Series
‎2022-03-29 2:18 PM
you are initializing several IPs alongside the WiFi Module, are you sure that there isn't any PIN conflict in your settings?
regards
haithem.
‎2022-03-29 3:04 PM
@Haithem Rahmani​
i copied files from this project: https://github.com/azure-rtos/getting-started/tree/master/STMicroelectronics/B-L4S5I-IOT01A so i trust that the project is without errors.
The problem seems to be related with SysTick.
‎2022-03-30 1:03 AM
@Haithem Rahmani​
Also i redefined "HAL_InitTick" based on: https://github.com/azure-rtos/getting-started/blob/master/STMicroelectronics/B-L4S5I-IOT01A/lib/stm32cubel4/Drivers/STM32L4xx_HAL_Driver/Src/stm32l4xx_hal_timebase_tim_template.c
but again i received this:
‎2022-03-30 6:01 AM
First of all could you check that the WiFi module is correctly working, try the example below.
‎2022-03-30 12:47 PM
‎2022-03-30 1:54 PM
@Haithem Rahmani​
Okey so i fix it and now its working but i have problem with add extra charts with datas from different sensors because a little bit don't understand code. If you have some time to explain couple of things how to add extra chart, i will be thankful
link to my project: https://github.com/jadczakoff/Azure_IoT_Project
‎2022-03-30 1:58 PM
well! I don't have any idea on this as this is Azure cloud related.
official Microsoft documentation may help.
https://docs.microsoft.com/en-us/azure/iot-hub/
https://docs.microsoft.com/en-us/azure/iot-dps/tutorial-set-up-cloud
‎2022-03-30 2:04 PM
@Haithem Rahmani​
Unfortunately, from what I can deduce from the code, all chart title settings, label x, y are set in the code, also if you know someone else who knows this, I would ask for some contact or let him write here.
‎2022-09-16 1:07 PM
I create a AZURE RTOS project for stm32h723 nucleo board with latest IDE, H7 and AZURE sdk. I couldnt get the "Netxduo/addons/azure_iot" to my custom code from select component section of tool, I guess there is a bug on STM32CUBEIDE.
Is there any workaround for that?
Umit
‎2022-09-20 2:15 AM
@umtkyck​
I had the same issue and I fixed that by adding manually this package. I had a lot of work but I recommend you download one of these package, choose a project to Stm32CubeIDE then find the folder where is azure_iot and finally copy it to your project and add a path to the linker. I believe that this file (azure_iot) is a general file for any microcontroller and you can copy that peacefully and configure on your own. I hope that it will help you
- « Previous
- 1
- 2
- Next »
