Timer + PWM + DMA
Options
2024-01-14 02:15 AM
I’m looking for some tutorial (or any other learning staff) related to Timer + PWM + DMA.
Unfortunately, I couldn’t find much info related to these issues.
I’d like to learn:
- LL_TIM_CC_EnableChannel() and LL_TIM_CC_DisableChannel():
- What exactly do these func do? When should IO use them?
- Is it available only while using DMA?
- What is the sequence of calling this func?
- Do I have to start DMA first using HAL_TIM_PWM_Start_DMA()?
- Will LL_TIM_CC_DisableChannel() stop/pause the DMA operation, or I must call HAL_TIM_PWM_Stop_DMA()?
- What is the flow chart (i.e.: sequence) of the MCU while using Timer + PWM + DMA? As far as I understood (please fix me:( Timer event --> “Send” data using to PWM DMA --> PWM operation on gpio (according to data)
Thanks,
Aviv
Options
2024-01-14 02:32 AM
Options
2024-01-15 02:49 AM
Thank you for your question !
I am adding some information / questions :
- You can also read this article named "Custom Signal generation using PWM and DMA"
- I need to know more about what is your application & STM32 product ? Can you please explain it ?
- According to User Manual LL_TIM_CC_EnableChannel() allow to enable capture/compare channels. Each Capture/Compare channel is built around a capture/compare register (including a shadow register), a input stage for capture (with digital filter, multiplexing and prescaler) and an output stage (with comparator and output control). To read more about capture/compare channels, read chapter 17.3.5 of the RM0090.
- Check also the 17.4.7 chapter, which mode are you interested in ?
Best Regards,
Pierre
