STM32L476 Discovery + HAL Library + FatFs
Options
2016-03-02 1:35 AM
Posted on March 02, 2016 at 10:35
Hello !
I would like to add some memory to the STM32L476 Discovery board.For that, I am trying to connect a microSD through SPI using FatFs.I found : http://stm32f4-discovery.com/2014/07/library-21-read-sd-card-fatfs-stm32f4xx-devices/ But it seems like the author is not using HAL and I tried to adapt it for my case but I didn't succeed.Is there any tutorials for that? #microsd #fatfs #hal #stm32l4
Labels:
Options
2016-03-02 6:48 AM
Posted on March 02, 2016 at 15:48
Hello Caeline,
You can find in ST web all tutorials related to STM32CubeL4: http://www.st.com/web/catalog/tools/FM147/CL1794/SC961/SS1743/LN1897/PF261908This user manual “http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00105259.pdf
� provides a description of how to use the STM32Cube firmware components with a generic FAT File System (FatFs). Also, you can refer to the release note of the STM32Cube firmware package to know the version of FatFs firmware component used. I suggest you have a look to this example to develop an application using most of the features offered by FatFs: STM32Cube_FW_L4_V1.3.0\Projects\STM32L476G_EVAL\Applications\FatFs\FatFs_uSD-ForumSTM32-
