STM32L471 DFU
Giuliano Scaglioni
Posted on July 12, 2017 at 07:55
I'm confused about wether STM32L471RG has a USB bootloader or not. AN2606 describes an STM32L47xxx DFU bootloader and that USB DM and USB DP lines should be connected to PA11 and PA12 respectively.
But what confuses me is that no USB FS DM/DP line is described on PA11/12 nor USB capabilities in
STM32L471RG
datasheet.
#stm32l4-usb #usb-bootloader #dfu #stm32l471 #dfu-bootloader
Nesrine M_O
Lead II
Posted on July 12, 2017 at 15:12
Hi
gscaglioni
The STM32L471xx device part numbers are not embedding the USB
, so DFU isn't supported.
The AN2606 application note is generic, with no mention of any details about part numbers.
So user has first to check related product datasheet then check AN26
-Nesrine-
3 REPLIES 3
Nesrine M_O
Lead II
Posted on July 12, 2017 at 11:48
Hi
gscaglioni
I will check this problem with our team & come back to you.Sorry for the inconvenience it may bring
-Nesrine-
Nesrine M_O
Lead II
Hi
gscaglioni
-Nesrine-
Posted on July 12, 2017 at 16:45
Thanks for your help!
