STM32L152 as USB host
i2
Posted on March 10, 2014 at 05:24
Has anyone used the STM32L series USB in host mode?
I'm looking at this part at design-in stage. I need the Capsense feature but I also need to use USB in host mode to support optional WiFi.. The ''circuit diagram'' on the website says it has USB OTG FS but I can see no reference in the specs.
#w5500 #usb-host #usb-stm32l
7 REPLIES 7
Posted on March 10, 2014 at 14:43
Do you clearly understand the programming/driver requirements of the WiFi module? How many end-points are utilized? Would an SPI/USART based WiFi module cause far less headaches?
i2
Posted on March 11, 2014 at 04:05
Thanks Clive, yes I know about the complexities. I have discussed it with our software engineers but I'm the hardware engineer in this project.
What we would like is the ability to optionally add wired or wireless Ethernet in the field to what is a price-sensitive product.
If the USB can run as host then we should be able to do this. If it can't, then we will have to look at other ways that will add cost to the basic product. Yes, SPI was my plan B if we can't get the USB to run host mode.
Is it possible on this chip?
If not, is there one with both Capsense and USB host capability?
Posted on March 11, 2014 at 09:52
As far as I'm aware the STM32L15x series didn't support USB FS OTG
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM000329pdf
What about the
http://www.st.com/web/en/catalog/mmc/FM141/SC1169/SS1295/LN1808/PF255680
? The diagram does say OTG, but the docs/sw don't seem to support it. Will push to moderation.
Amel NASRI
Posted on March 11, 2014 at 13:23
Hi Clive1,
I confirm; STM32L1 doesn't support USB OTG FS. This includes STM32L100.
Thanks for your relevant feedbacks Clive1, issue with web diagrams will be fixed soon.
-Mayla-
Posted on March 11, 2014 at 14:26
Thank you for the clarification.
i2
Posted on March 12, 2014 at 01:00
Thanks All, I suspected as much. Copy and Paste error!
OK, I am resigned to using SPI to interface the Ethernet. Initially looked at the ENC28J60 from Microchip but the W5500 from Wiznet looks more interesting, it integrates the TCP-IP stack which looks like it would make the software dev much easier.
Anyone else gone down this route?
Do ST have anything like this?
i2
Posted on March 13, 2014 at 00:15
While chasing up magnetics info for the W5500 I found this:
http://wizwiki.net/wiki/doku.php?id=products:w5500:driver
