stm32l0xx, USB Custom HID with firmware 1.12.1 send report problem:
‎2022-11-16 9:07 AM
USBD_CUSTOM_HID_SendReport(...) returns USBD_OK but nothing being send when code is generated with firmware version 1.12.1, but this function works without any problem in firmware 1.12.0
STM32Cube MCU Packages
STM32L0 Series
USB
‎2022-11-17 10:34 AM
‎2022-11-17 11:19 AM
Post1 seems to be the solution. I confirm that version 1.12.0 that works correctly uses HAL_PCD_EP_Transmit(...) and the version 1.12.1 that does not work uses HAL_PCD_EP_DB_Transmit (...).
‎2022-11-28 12:54 AM
Hi @HAHA​ ,
In the release note of STM32CubeL0 version 1.12.1, there is this message:
HAL USB_FS update
HAL PCD: add fix transfer complete for IN Interrupt transaction in single buffer mode.
For customHID user should not use HAL_PCD_EP_DB_Transmit this is specific for ISO and bulk transfers not Interrupt.
I escalated your feedback internally for check within an Internal ticket number: 139848.
(PS: This tracking number (139848) is only for reference and is not accessible or usable by customers).
Imen
Imen
‎2022-11-28 5:02 AM
Hi @HAHA​,
Can you please confirm that the issue is reproduced when the code generation is with STM32CubeMX, or only when using HAL USB?
Imen
Imen
‎2022-11-30 6:06 AM
Hi Imen,
the issue is reproduced when the code is generated with STM32CubeMX.
HA.
‎2022-11-30 6:20 AM
Hi @HAHA​ ,
Thanks for this detail.
So, the issue is with STM32CubeMx. I will escalate this to the appropriate team.
Imen
Imen
‎2022-12-16 9:50 AM
Hi @HAHA​ ,
Can you please share your ioc file to check this issue in your project.
Imen
Imen
‎2023-01-09 11:06 AM
Hello @HAHA​,
This issue is not reproduced on side CubeMx team.
Could you please provide the project (ioc file) to check this behavior.
Imen
Imen
‎2023-01-10 8:29 AM
Hi Imen,
sorry for the delay, attached please find the whole sample project that shows the problem. The application is supposed to send an "a" as a keyboard stroke on startup. If you change the firmware to revision 1.12.0 this application works as it should.
let me know if you have any questions.
H.
