STM32L0 - How to set Single-Ended Mode on an ADC Channel on STM32 using the HAL library?
David Smith
Current settings seem to only produce 0x000 to 0x7FF . The HAL API on the STM32L0 only has 2 Parameters in the ADC ChannelConf Type:
typedef struct
 uint32_t Channel;
 uint32_t Rank;
}ADC_ChannelConfTypeDef;
Which is Clearly missing the : sConfig.SingleDiff = ADC_SINGLE_ENDED; feature....
Our current Settings:
static void MX_ADC_Init(void)
 ADC_ChannelConfTypeDef sConfig;
  /**Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
 hadc.Instance = ADC1;
 hadc.Init.OversamplingMode = DISABLE;
 hadc.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV1;
 hadc.Init.Resolution = ADC_RESOLUTION_12B;
 hadc.Init.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
 hadc.Init.ScanConvMode = ENABLED;
 hadc.Init.DataAlign = ADC_DATAALIGN_RIGHT;
 hadc.Init.ContinuousConvMode = ENABLED;
 hadc.Init.DiscontinuousConvMode = DISABLE;
 hadc.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
 hadc.Init.ExternalTrigConv = ADC_SOFTWARE_START;
 hadc.Init.DMAContinuousRequests = DISABLE;
 hadc.Init.EOCSelection = ADC_EOC_SINGLE_CONV;
 hadc.Init.Overrun = ADC_OVR_DATA_PRESERVED;
 hadc.Init.LowPowerAutoWait = ENABLE; // new..
 hadc.Init.LowPowerFrequencyMode = DISABLE;
 hadc.Init.LowPowerAutoPowerOff = DISABLE;
 if (HAL_ADC_Init(&hadc) != HAL_OK)
  _Error_Handler(__FILE__, __LINE__);
// Had hoped THIS would work - but no
 if (HAL_ADCEx_Calibration_Start(&hadc, ADC_SINGLE_ENDED) != HAL_OK) {
   Error_Handler();
  // Configure for the selected ADC regular channel to be converted.
 sConfig.Rank   = 1;
 sConfig.Channel = ADC_CHANNEL_8;
 if (HAL_ADC_ConfigChannel(&hadc, &sConfig) != HAL_OK)
  /**Configure for the selected ADC regular channel to be converted.
 sConfig.Rank   = 2;
 sConfig.Channel = ADC_CHANNEL_9;
Anyone have some thoughts on this? Would REALLY like to get to 0x000 to 0xFFF
2 REPLIES 2
David Smith
Anyone??
FMuel.2
Hi @Community member​ - could you solve the problem? I would higly appreciate a solution or advice to your problem since I have the same issue.
