Stm32h745, freertos&LWIP is hogging SRAM1 memory.
‎2021-10-29 4:24 AM
LWIP is hogging memory where it didnt oughta be.
...\ld.exe: section .SRAM2 VMA [0000000030020000,0000000030031033] overlaps section .lwip_sec VMA [0000000030000000,00000000300419cf]
but in the .ld file is allocated thus
/* ethernet Modification start */
.lwip_sec (NOLOAD) : {
. = ABSOLUTE(0x30040000);
*(.RxDecripSection)
. = ABSOLUTE(0x30040060);
*(.TxDecripSection)
. = ABSOLUTE(0x30040200);
*(.RxArraySection)
} >RAM_D2
Why does LWIP behave this way please?, what might I be doing wrong here?
It all seems to work cm7 wise(though clearly the CM4 core memory SRAM1,SRAM2 that aliases here is not available) . I have put the uncached dma buffer that was in CM7 SRAM in a block of axiram, but this is a bodge.
- Labels:
Ethernet
FreeRTOS
STM32H7 Series
‎2021-10-29 4:47 AM
This seems to have fixed it, though I don't understand why it is necessary to create the additional memory sub region
"RAM3_D2 (xrw) : ORIGIN = 0x30040000, LENGTH = 32K":
/* Memories definition */
MEMORY
RAM_D1 (xrw) : ORIGIN = 0x24000000, LENGTH = 512K
HIAXIRAM (xrw) : ORIGIN = 0x24060000, LENGTH = 128K
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1024K /* Memory is divided. Actual start is 0x08000000 and actual length is 2048K */
DTCMRAM (xrw) : ORIGIN = 0x20000000, LENGTH = 128K
RAM_D2 (xrw) : ORIGIN = 0x30000000, LENGTH = 288K
SRAM_2 (xrw) : ORIGIN = 0x30020000, LENGTH = 128K
SRAM_1 (xrw) : ORIGIN = 0x30000000, LENGTH = 128K
RAM_D3 (xrw) : ORIGIN = 0x38000000, LENGTH = 64K
ITCMRAM (xrw) : ORIGIN = 0x00000000, LENGTH = 64K
*(.RxDecripSection)
*(.TxDecripSection)
*(.RxArraySection)
} >RAM3_D2
‎2021-10-29 4:47 AM
MEMORY
*(.RxDecripSection)
*(.TxDecripSection)
*(.RxArraySection)
} >RAM3_D2
