2019-10-07 1:41 PM
The ADC is configured as shown below. TIM3 is configured: 200ms, Count Down, Auto-reload Enable, MSM Disabled and TRGO=Update Event. HAL_ADC_ConvCpltCallback() is called once at the apparent end of the first sequence with good data on each channel. I'm expecting an interrupt ever y 200ms. What am I missing?
void MX_ADC1_Init(void)
ADC_ChannelConfTypeDef sConfig = {0};
/** Configure the global features of the ADC (Clock, Resolution, Data Alignment and number of conversion)
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_SYNC_PCLK_DIV4;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.ScanConvMode = ADC_SCAN_SEQ_FIXED;
hadc1.Init.EOCSelection = ADC_EOC_SEQ_CONV;
hadc1.Init.LowPowerAutoWait = DISABLE;
hadc1.Init.LowPowerAutoPowerOff = ENABLE;
hadc1.Init.ContinuousConvMode = DISABLE;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConv = ADC_EXTERNALTRIG_T3_TRGO;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_RISING;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
hadc1.Init.SamplingTimeCommon1 = ADC_SAMPLETIME_1CYCLE_5;
hadc1.Init.OversamplingMode = ENABLE;
hadc1.Init.Oversampling.Ratio = ADC_OVERSAMPLING_RATIO_32;
hadc1.Init.Oversampling.RightBitShift = ADC_RIGHTBITSHIFT_5;
hadc1.Init.Oversampling.TriggeredMode = ADC_TRIGGEREDMODE_SINGLE_TRIGGER;
hadc1.Init.TriggerFrequencyMode = ADC_TRIGGER_FREQ_LOW;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure Regular Channel
sConfig.Channel = ADC_CHANNEL_0;
sConfig.Rank = ADC_RANK_CHANNEL_NUMBER;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
Error_Handler();
sConfig.Channel = ADC_CHANNEL_1;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_2;
sConfig.Rank = 1;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_3;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_4;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_5;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_6;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_7;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_8;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_9;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_11;
Error_Handler();
sConfig.Channel = ADC_CHANNEL_16;
Error_Handler();
