STM32F765 and LAN8720A
raffin
the LAN8720A has not the Tx_clk and Rx_Clk signals. Does the STM32F765 supports this configuration supposed I use the LAN8720A in slave mode routing to it the 25MHZ clock generated from the MCU from a ClockOut pin?
Thank you.
Romano1
In fact you couldn't use MII ethernet with the LAN8720A only RMII is available on it.
