STM32F4xx - UART - HAL - Hardware flow control.
‎2017-02-05 6:40 AM
Does CTS/RTS signals get asserted or de-asserted between transmitter and receiver by just enabling hardware flow control for UART in stm32cube software ?
Do I need to check the statuses of CTS/RTS signals for using HAL functions like HAL_UART_Transmit() or HAL_UART_Receive() or HAL_UART_Receive_IT(). ? or Do I need to assert or de-assert those signals for communication to happen ?
#hal #stm32-uart-hardware-flow-rts/cts #stm32f4- Mark as New
‎2017-02-27 10:22 AM
Hi, I'm trying to use it as well, and obsrving what is going on with a logic analyzer, and I can see the RTS line getting low when I want to transmit something. I guess the answer is that the configuration you make on CubeMX is enough for the flow control happen during the communcation.
I'm having another problem, though: I programmed my board to turn on the LEDs if the trasmissions is sucsessful, and it turns them on, but I can't see anything in te logic analyzer.
Were you able to find your answer since you posted this message? If you did, please let me know
VÃÂtor Pereira
‎2017-02-27 9:31 PM
Hello Vitor,
After enabling Hardware flow control, I was able to transmit and receive data between STM32F4 MCU and a bluetooth module which also has Hardware flow control enabled. The communication was fine. I guess no need to assert or de-assert the CTS/RTS signals or check the status of the signals.
Good luck.
Thanks,
‎2017-02-28 11:18 AM
Nice that you did it! I'm also working with a bluetooth module.
Thanks for the reply.
VÃtor Pereira
‎2017-03-03 1:39 PM
Indeed, once the Hardware flow control is enabled, you don't need to monitor the CTS status or to set the RTS signal.You can can callHAL_UART_Transmit() or HAL_UART_Receive() or HAL_UART_Receive_IT()
directly.Regards,
Réjane
‎2018-01-17 8:32 AM
I confirm that with CTS and RTS wired with the other board, the communication works well.
I tried to use bad wiring ( short-circuit the RTS and CTS lines), and the communication still work well,More over, if i wire only the CTS of the STM32 to the RTS of my board, the communication still work well.I used various data size, 1 byte and more.I want to know if this behaviour is normal.I'm using STM32L486xx Device.Without wiring the CTS and RTS, it doesn't work as expected.Thanks.
‎2018-01-17 8:52 AM
Doesn't seem unreasonable, one of the pins is an input, the other is an output. ie you can report your own state, and choose to use or ignore the remote's state
‎2018-01-23 8:20 AM
Hi CLive,
Do you have any explanation about why when i short-circuit the CTS-RTS lines between 2 boards, the communications still works fine?
In my case, i am using UART polling mode, half duplex communication, and my USART pins are configured pullup'tried with pulldown also'.
‎2018-01-23 8:59 AM
looping back the flow-control lines pretty much signals 'ready for data' all the time, neither side will wait, equivalent to not having flow control.
