STM32F4discovery hight speed USB
Options
‎2012-11-29 8:15 PM
Posted on November 30, 2012 at 05:15
Hi:
I am using the USB part of audio playback sample code of STM32F4 discovery. In waverecorder.c I customized the recorder_update() function. I think it stores data at the rate of 12Mbps in USB. M i right? I want to speed up the transfer rate. how is it possible? thanks #usb-storage-hs
Labels:
USB
Options
‎2012-11-30 3:40 AM
Posted on November 30, 2012 at 12:40
You need an external PHY for High Speed USB. If it's not practical/desirable to add one consider a different eval board, I recall seeing some on eBay
Options
‎2012-12-02 8:54 PM
Posted on December 03, 2012 at 05:54 thnks. I wanna ask in audio example it uses full speed... did it use 12Mbps or slower than that to store data in USB? regards
