stm32f3xx_hal_def.h should be modified
‎2024-07-12 6:43 AM
IMHO in the file "stm32f3xx_hal_def.h" the section "Exported types" should be moved in front off section "Includes", because some of the types are used in the included files, but "stm32f3xx_hal_def.h" will not be reentered. It produces error like this:
In file included from .\Core\Inc/stm32f3xx_hal_conf.h:203,
from .\Drivers\STM32F3xx_HAL_Driver\Inc/stm32f3xx_hal.h:29,
from .\Drivers\CMSIS\Device\ST\STM32F3xx\Include/stm32f3xx.h:266,
from .\Drivers\STM32F3xx_HAL_Driver\Inc/stm32f3xx_hal_def.h:29,
from .\Drivers\STM32F3xx_HAL_Driver\Inc/stm32f3xx_hal_rcc.h:27,
from Src\setup.cpp:9:
.\Drivers\STM32F3xx_HAL_Driver\Inc/stm32f3xx_hal_gpio.h:297:1: error: 'HAL_StatusTypeDef' does not name a type; did you mean 'NOR_StatusTypedef'?
‎2024-07-12 7:14 AM
Ok, thanks, including "stm32f3xx_hal.h" instead of "stm32f3xx_hal_conf.h" fixed things!
I believe, though, that a good practice is to include the minimal amount of include stuff, and there is no reason not to do this modification.
IOC file:
#MicroXplorer Configuration settings - do not modify
CAD.formats=
CAD.pinconfig=
CAD.provider=
COMP1.IPParameters=InvertingInput,TriggerMode
COMP1.InvertingInput=COMP_INVERTINGINPUT_1_4VREFINT
COMP1.TriggerMode=COMP_TRIGGERMODE_IT_RISING
DAC.DAC_OutputBuffer=DAC_OUTPUTBUFFER_DISABLE
DAC.DAC_Trigger=DAC_TRIGGER_T6_TRGO
DAC.IPParameters=DAC_OutputBuffer,DAC_Trigger
Dma.DAC_CH1.0.Direction=DMA_MEMORY_TO_PERIPH
Dma.DAC_CH1.0.Instance=DMA1_Channel3
Dma.DAC_CH1.0.MemDataAlignment=DMA_MDATAALIGN_HALFWORD
Dma.DAC_CH1.0.MemInc=DMA_MINC_ENABLE
Dma.DAC_CH1.0.Mode=DMA_NORMAL
Dma.DAC_CH1.0.PeriphDataAlignment=DMA_PDATAALIGN_HALFWORD
Dma.DAC_CH1.0.PeriphInc=DMA_PINC_DISABLE
Dma.DAC_CH1.0.Priority=DMA_PRIORITY_LOW
Dma.DAC_CH1.0.RequestParameters=Instance,Direction,PeriphInc,MemInc,PeriphDataAlignment,MemDataAlignment,Mode,Priority
Dma.Request0=DAC_CH1
Dma.Request1=USART2_TX
Dma.RequestsNb=2
Dma.USART2_TX.1.Direction=DMA_MEMORY_TO_PERIPH
Dma.USART2_TX.1.Instance=DMA1_Channel7
Dma.USART2_TX.1.MemDataAlignment=DMA_MDATAALIGN_BYTE
Dma.USART2_TX.1.MemInc=DMA_MINC_ENABLE
Dma.USART2_TX.1.Mode=DMA_NORMAL
Dma.USART2_TX.1.PeriphDataAlignment=DMA_PDATAALIGN_BYTE
Dma.USART2_TX.1.PeriphInc=DMA_PINC_DISABLE
Dma.USART2_TX.1.Priority=DMA_PRIORITY_LOW
Dma.USART2_TX.1.RequestParameters=Instance,Direction,PeriphInc,MemInc,PeriphDataAlignment,MemDataAlignment,Mode,Priority
File.Version=6
GPIO.groupedBy=Group By Peripherals
I2C1.IPParameters=Timing-I2C
I2C1.Timing-I2C=0x2000090E
KeepUserPlacement=false
Mcu.CPN=STM32F303VCT6
Mcu.Family=STM32F3
Mcu.IP0=COMP1
Mcu.IP1=DAC
Mcu.IP10=TIM6
Mcu.IP11=USART2
Mcu.IP2=DMA
Mcu.IP3=I2C1
Mcu.IP4=NVIC
Mcu.IP5=OPAMP1
Mcu.IP6=OPAMP4
Mcu.IP7=RCC
Mcu.IP8=SPI1
Mcu.IP9=SYS
Mcu.IPNb=12
Mcu.Name=STM32F303V(B-C)Tx
Mcu.Package=LQFP100
Mcu.Pin0=PE2
Mcu.Pin1=PE3
Mcu.Pin10=PA2
Mcu.Pin11=PA3
Mcu.Pin12=PA4
Mcu.Pin13=PA5
Mcu.Pin14=PA6
Mcu.Pin15=PA7
Mcu.Pin16=PC5
Mcu.Pin17=PE8
Mcu.Pin18=PE9
Mcu.Pin19=PE10
Mcu.Pin2=PE4
Mcu.Pin20=PE11
Mcu.Pin21=PE12
Mcu.Pin22=PE13
Mcu.Pin23=PE14
Mcu.Pin24=PE15
Mcu.Pin25=PB12
Mcu.Pin26=PA11
Mcu.Pin27=PA12
Mcu.Pin28=PA13
Mcu.Pin29=PA14
Mcu.Pin3=PE5
Mcu.Pin30=PA15
Mcu.Pin31=PD5
Mcu.Pin32=PB3
Mcu.Pin33=PB6
Mcu.Pin34=PB7
Mcu.Pin35=PE0
Mcu.Pin36=PE1
Mcu.Pin37=VP_COMP1_VS_VREFINT14
Mcu.Pin38=VP_SYS_VS_Systick
Mcu.Pin39=VP_TIM6_VS_ClockSourceINT
Mcu.Pin4=PC14-OSC32_IN
Mcu.Pin5=PC15-OSC32_OUT
Mcu.Pin6=PF0-OSC_IN
Mcu.Pin7=PF1-OSC_OUT
Mcu.Pin8=PA0
Mcu.Pin9=PA1
Mcu.PinsNb=40
Mcu.ThirdPartyNb=0
Mcu.UserConstants=
Mcu.UserName=STM32F303VCTx
MxCube.Version=6.11.1
MxDb.Version=DB.6.0.111
NVIC.BusFault_IRQn=true\:0\:0\:false\:false\:true\:true\:false\:false
NVIC.COMP1_2_3_IRQn=true\:0\:0\:false\:false\:true\:false\:true\:true
NVIC.DMA1_Channel3_IRQn=true\:0\:0\:false\:false\:true\:false\:true\:true
NVIC.DMA1_Channel7_IRQn=true\:0\:0\:false\:false\:true\:false\:true\:true
NVIC.DebugMonitor_IRQn=true\:0\:0\:false\:false\:true\:true\:false\:false
NVIC.ForceEnableDMAVector=true
NVIC.HardFault_IRQn=true\:0\:0\:false\:false\:true\:true\:false\:false
NVIC.MemoryManagement_IRQn=true\:0\:0\:false\:false\:true\:true\:false\:false
NVIC.NonMaskableInt_IRQn=true\:0\:0\:false\:false\:true\:true\:false\:false
NVIC.PendSV_IRQn=true\:0\:0\:false\:false\:true\:false\:false\:false
NVIC.PriorityGroup=NVIC_PRIORITYGROUP_0
NVIC.SVCall_IRQn=true\:0\:0\:false\:false\:true\:false\:false\:false
NVIC.SysTick_IRQn=true\:0\:0\:true\:false\:true\:true\:true\:false
NVIC.USART2_IRQn=true\:0\:0\:false\:false\:true\:true\:true\:true
NVIC.UsageFault_IRQn=true\:0\:0\:false\:false\:true\:true\:false\:false
PA0.GPIOParameters=GPIO_Label
PA0.GPIO_Label=B1 [Blue PushButton]
PA0.Locked=true
PA0.Signal=GPIO_Input
PA1.GPIOParameters=GPIO_Label
PA1.GPIO_Label=COMP_IN1
PA1.Mode=INP
PA1.Signal=COMP1_INP
PA11.GPIOParameters=GPIO_Label
PA11.GPIO_Label=DM
PA11.Locked=true
PA11.Signal=USB_DM
PA12.GPIOParameters=GPIO_Label
PA12.GPIO_Label=DP
PA12.Locked=true
PA12.Signal=USB_DP
PA13.GPIOParameters=GPIO_Label
PA13.GPIO_Label=SWDIO
PA13.Locked=true
PA13.Mode=Serial_Wire
PA13.Signal=SYS_JTMS-SWDIO
PA14.GPIOParameters=GPIO_Label
PA14.GPIO_Label=SWCLK
PA14.Locked=true
PA14.Mode=Serial_Wire
PA14.Signal=SYS_JTCK-SWCLK
PA15.GPIOParameters=GPIO_Label
PA15.GPIO_Label=TO_GREEN
PA15.Mode=Asynchronous
PA15.Signal=USART2_RX
PA2.Mode=Standalone
PA2.Signal=OPAMP1_VOUT
PA3.Mode=Standalone
PA3.Signal=OPAMP1_VINP
PA4.GPIOParameters=GPIO_Label
PA4.GPIO_Label=DAC_OUT
PA4.Signal=COMP_DAC1_group
PA5.GPIOParameters=GPIO_Label
PA5.GPIO_Label=SPI1_SCK [L3GD20_SCL/SPC]
PA5.Locked=true
PA5.Mode=Full_Duplex_Master
PA5.Signal=SPI1_SCK
PA6.GPIOParameters=GPIO_Label
PA6.GPIO_Label=SPI1_MISO [L3GD20_SA0/SDO]
PA6.Locked=true
PA6.Mode=Full_Duplex_Master
PA6.Signal=SPI1_MISO
PA7.GPIOParameters=GPIO_Label
PA7.GPIO_Label=SPI1_MISO [L3GD20_SDA/SDI/SDO]
PA7.Locked=true
PA7.Mode=Full_Duplex_Master
PA7.Signal=SPI1_MOSI
PB12.GPIOParameters=GPIO_Label
PB12.GPIO_Label=DAC_OPAMP_VOUT
PB12.Mode=Follower-DAC_OUT1-INP
PB12.Signal=OPAMP4_VOUT
PB3.GPIOParameters=GPIO_Label
PB3.GPIO_Label=SWO
PB3.Locked=true
PB3.Signal=SYS_JTDO-TRACESWO
PB6.GPIOParameters=GPIO_Label,GPIO_Pu
PB6.GPIO_Label=I2C1_SCL [LSM303DLHC_SCL]
PB6.GPIO_Pu=GPIO_PULLUP
PB6.Locked=true
PB6.Mode=I2C
PB6.Signal=I2C1_SCL
PB7.GPIOParameters=GPIO_Label,GPIO_Pu
PB7.GPIO_Label=I2C1_SDA [LSM303DLHC_SDA]
PB7.GPIO_Pu=GPIO_PULLUP
PB7.Locked=true
PB7.Mode=I2C
PB7.Signal=I2C1_SDA
PC14-OSC32_IN.GPIOParameters=GPIO_Label
PC14-OSC32_IN.GPIO_Label=OSC32_IN
PC14-OSC32_IN.Locked=true
PC14-OSC32_IN.Signal=RCC_OSC32_IN
PC15-OSC32_OUT.GPIOParameters=GPIO_Label
PC15-OSC32_OUT.GPIO_Label=OSC32_OUT
PC15-OSC32_OUT.Locked=true
PC15-OSC32_OUT.Signal=RCC_OSC32_OUT
PC5.Mode=Standalone
PC5.Signal=OPAMP1_VINM
PD5.GPIOParameters=GPIO_Label
PD5.GPIO_Label=TO_WHITE
PD5.Mode=Asynchronous
PD5.Signal=USART2_TX
PE0.GPIOParameters=GPIO_Label,GPIO_ModeDefaultEXTI
PE0.GPIO_Label=MEMS_INT1 [L3GD20_INT1]
PE0.GPIO_ModeDefaultEXTI=GPIO_MODE_EVT_RISING
PE0.Locked=true
PE0.Signal=GPXTI0
PE1.GPIOParameters=GPIO_Label,GPIO_ModeDefaultEXTI
PE1.GPIO_Label=MEMS_INT2 [L3GD20_DRDY/INT2]
PE1.GPIO_ModeDefaultEXTI=GPIO_MODE_EVT_RISING
PE1.Locked=true
PE1.Signal=GPXTI1
PE10.GPIOParameters=GPIO_Label
PE10.GPIO_Label=LD5 [Orange Led]
PE10.Locked=true
PE10.Signal=GPIO_Output
PE11.GPIOParameters=GPIO_Label
PE11.GPIO_Label=LD7 [Green Led]
PE11.Locked=true
PE11.Signal=GPIO_Output
PE12.GPIOParameters=GPIO_Label
PE12.GPIO_Label=LD9 [Blue Led]
PE12.Locked=true
PE12.Signal=GPIO_Output
PE13.GPIOParameters=GPIO_Label
PE13.GPIO_Label=LD10 [Red Led]
PE13.Locked=true
PE13.Signal=GPIO_Output
PE14.GPIOParameters=GPIO_Label
PE14.GPIO_Label=LD8 [Orange Led]
PE14.Locked=true
PE14.Signal=GPIO_Output
PE15.GPIOParameters=GPIO_Label
PE15.GPIO_Label=LD6 [Green Led]
PE15.Locked=true
PE15.Signal=GPIO_Output
PE2.GPIOParameters=GPIO_Label,GPIO_ModeDefaultEXTI
PE2.GPIO_Label=DRDY [LSM303DLHC_DRDY]
PE2.GPIO_ModeDefaultEXTI=GPIO_MODE_EVT_RISING
PE2.Locked=true
PE2.Signal=GPXTI2
PE3.GPIOParameters=GPIO_Label
PE3.GPIO_Label=CS_I2C/SPI [L3GD20_CS_I2C/SPI]
PE3.Locked=true
PE3.Signal=GPIO_Output
PE4.GPIOParameters=GPIO_Label,GPIO_ModeDefaultEXTI
PE4.GPIO_Label=MEMS_INT3 [LSM303DLHC_INT1]
PE4.GPIO_ModeDefaultEXTI=GPIO_MODE_EVT_RISING
PE4.Locked=true
PE4.Signal=GPXTI4
PE5.GPIOParameters=GPIO_Label,GPIO_ModeDefaultEXTI
PE5.GPIO_Label=MEMS_INT4 [LSM303DLHC_INT2]
PE5.GPIO_ModeDefaultEXTI=GPIO_MODE_EVT_RISING
PE5.Locked=true
PE5.Signal=GPXTI5
PE8.GPIOParameters=GPIO_Label
PE8.GPIO_Label=LD4 [Blue Led]
PE8.Locked=true
PE8.Signal=GPIO_Output
PE9.GPIOParameters=GPIO_Label
PE9.GPIO_Label=LD3 [Red Led]
PE9.Locked=true
PE9.Signal=GPIO_Output
PF0-OSC_IN.GPIOParameters=GPIO_Label
PF0-OSC_IN.GPIO_Label=OSC_IN
PF0-OSC_IN.Locked=true
PF0-OSC_IN.Mode=HSE-External-Clock-Source
PF0-OSC_IN.Signal=RCC_OSC_IN
PF1-OSC_OUT.GPIOParameters=GPIO_Label
PF1-OSC_OUT.GPIO_Label=OSC_OUT
PF1-OSC_OUT.Locked=true
PF1-OSC_OUT.Signal=RCC_OSC_OUT
PinOutPanel.RotationAngle=0
ProjectManager.AskForMigrate=true
ProjectManager.BackupPrevious=false
ProjectManager.CompilerOptimize=6
ProjectManager.ComputerToolchain=false
ProjectManager.CoupleFile=false
ProjectManager.CustomerFirmwarePackage=
ProjectManager.DefaultFWLocation=true
ProjectManager.DeletePrevious=true
ProjectManager.DeviceId=STM32F303VCTx
ProjectManager.FirmwarePackage=STM32Cube FW_F3 V1.11.5
ProjectManager.FreePins=true
ProjectManager.HalAssertFull=true
ProjectManager.HeapSize=0x200
ProjectManager.KeepUserCode=true
ProjectManager.LastFirmware=true
ProjectManager.LibraryCopy=1
ProjectManager.MainLocation=Core/Src
ProjectManager.NoMain=false
ProjectManager.PreviousToolchain=STM32CubeIDE
ProjectManager.ProjectBuild=false
ProjectManager.ProjectFileName=F3discovery.ioc
ProjectManager.ProjectName=F3discovery
ProjectManager.ProjectStructure=
ProjectManager.RegisterCallBack=
ProjectManager.StackSize=0x400
ProjectManager.TargetToolchain=STM32CubeIDE
ProjectManager.ToolChainLocation=
ProjectManager.UAScriptAfterPath=
ProjectManager.UAScriptBeforePath=
ProjectManager.UnderRoot=true
ProjectManager.functionlistsort=1-SystemClock_Config-RCC-false-HAL-false,2-MX_GPIO_Init-GPIO-false-HAL-true,3-MX_DMA_Init-DMA-false-HAL-true,4-MX_DAC_Init-DAC-false-HAL-true,5-MX_I2C1_Init-I2C1-false-HAL-true,6-MX_SPI1_Init-SPI1-false-HAL-true,7-MX_OPAMP4_Init-OPAMP4-false-HAL-true,8-MX_TIM7_Init-TIM7-false-HAL-true,8-MX_COMP1_Init-COMP1-false-HAL-true,9-MX_OPAMP1_Init-OPAMP1-false-HAL-true,10-MX_USART2_UART_Init-USART2-false-HAL-true,11-MX_TIM6_Init-TIM6-false-HAL-true
RCC.ADC12outputFreq_Value=48000000
RCC.ADC34outputFreq_Value=48000000
RCC.AHBFreq_Value=48000000
RCC.APB1CLKDivider=RCC_HCLK_DIV2
RCC.APB1Freq_Value=24000000
RCC.APB1TimFreq_Value=48000000
RCC.APB2Freq_Value=48000000
RCC.APB2TimFreq_Value=48000000
RCC.CortexFreq_Value=48000000
RCC.FCLKCortexFreq_Value=48000000
RCC.FamilyName=M
RCC.HCLKFreq_Value=48000000
RCC.HSEPLLFreq_Value=8000000
RCC.HSE_VALUE=8000000
RCC.HSIPLLFreq_Value=4000000
RCC.HSI_VALUE=8000000
RCC.I2C1Freq_Value=8000000
RCC.I2C2Freq_Value=8000000
RCC.I2SClocksFreq_Value=48000000
RCC.IPParameters=ADC12outputFreq_Value,ADC34outputFreq_Value,AHBFreq_Value,APB1CLKDivider,APB1Freq_Value,APB1TimFreq_Value,APB2Freq_Value,APB2TimFreq_Value,CortexFreq_Value,FCLKCortexFreq_Value,FamilyName,HCLKFreq_Value,HSEPLLFreq_Value,HSE_VALUE,HSIPLLFreq_Value,HSI_VALUE,I2C1Freq_Value,I2C2Freq_Value,I2SClocksFreq_Value,LSE_VALUE,LSI_VALUE,MCOFreq_Value,PLLCLKFreq_Value,PLLMCOFreq_Value,PLLMUL,PLLSourceVirtual,RTCFreq_Value,RTCHSEDivFreq_Value,SYSCLKFreq_VALUE,SYSCLKSourceVirtual,TIM1Freq_Value,TIM2Freq_Value,TIM8Freq_Value,UART4Freq_Value,UART5Freq_Value,USART1Freq_Value,USART2Freq_Value,USART3Freq_Value,USBFreq_Value,VCOOutput2Freq_Value
RCC.LSE_VALUE=32768
RCC.LSI_VALUE=40000
RCC.MCOFreq_Value=48000000
RCC.PLLCLKFreq_Value=48000000
RCC.PLLMCOFreq_Value=24000000
RCC.PLLMUL=RCC_PLL_MUL6
RCC.PLLSourceVirtual=RCC_PLLSOURCE_HSE
RCC.RTCFreq_Value=40000
RCC.RTCHSEDivFreq_Value=250000
RCC.SYSCLKFreq_VALUE=48000000
RCC.SYSCLKSourceVirtual=RCC_SYSCLKSOURCE_PLLCLK
RCC.TIM1Freq_Value=48000000
RCC.TIM2Freq_Value=48000000
RCC.TIM8Freq_Value=48000000
RCC.UART4Freq_Value=24000000
RCC.UART5Freq_Value=24000000
RCC.USART1Freq_Value=48000000
RCC.USART2Freq_Value=24000000
RCC.USART3Freq_Value=24000000
RCC.USBFreq_Value=48000000
RCC.VCOOutput2Freq_Value=8000000
SH.COMP_DAC1_group.0=DAC_OUT1,DAC_OUT1
SH.COMP_DAC1_group.ConfNb=1
SH.GPXTI0.0=GPIO_EXTI0
SH.GPXTI0.ConfNb=1
SH.GPXTI1.0=GPIO_EXTI1
SH.GPXTI1.ConfNb=1
SH.GPXTI2.0=GPIO_EXTI2
SH.GPXTI2.ConfNb=1
SH.GPXTI4.0=GPIO_EXTI4
SH.GPXTI4.ConfNb=1
SH.GPXTI5.0=GPIO_EXTI5
SH.GPXTI5.ConfNb=1
SPI1.BaudRatePrescaler=SPI_BAUDRATEPRESCALER_4
SPI1.BaudRatePrescaler-Full_Duplex_Master=SPI_BAUDRATEPRESCALER_2
SPI1.CalculateBaudRate=12.0 MBits/s
SPI1.CalculateBaudRate-Full_Duplex_Master=24.0 MBits/s
SPI1.Direction=SPI_DIRECTION_2LINES
SPI1.IPParameters=CalculateBaudRate,BaudRatePrescaler,CalculateBaudRate-Full_Duplex_Master,BaudRatePrescaler-Full_Duplex_Master,Mode-Full_Duplex_Master,Mode,VirtualType,Direction
SPI1.Mode=SPI_MODE_MASTER
SPI1.Mode-Full_Duplex_Master=SPI_MODE_MASTER
SPI1.VirtualType=VM_MASTER
TIM6.IPParameters=TIM_MasterOutputTrigger
TIM6.TIM_MasterOutputTrigger=TIM_TRGO_UPDATE
USART2.BaudRate=115200
USART2.IPParameters=VirtualMode-Asynchronous,BaudRate
USART2.VirtualMode-Asynchronous=VM_ASYNC
VP_COMP1_VS_VREFINT14.Mode=VREFINT_14
VP_COMP1_VS_VREFINT14.Signal=COMP1_VS_VREFINT14
VP_SYS_VS_Systick.Mode=SysTick
VP_SYS_VS_Systick.Signal=SYS_VS_Systick
VP_TIM6_VS_ClockSourceINT.Mode=Enable_Timer
VP_TIM6_VS_ClockSourceINT.Signal=TIM6_VS_ClockSourceINT
board=STM32F3DISCOVERY
boardIOC=true
‎2024-07-12 6:49 AM - edited ‎2024-07-12 6:52 AM
Do you have an IOC file that generates code that produces these errors? If so can you attach it here?
Seems like an issue of not including the correct top-level HAL file. You should be including "stm32f3xx_hal.h" first (and only, generally) from your source file. The error message suggests #include "stm32f3xx_hal_conf.h" is first.
‎2024-07-12 7:14 AM
IOC file:
CAD.formats=
CAD.pinconfig=
CAD.provider=
Dma.RequestsNb=2
File.Version=6
Mcu.Family=STM32F3
Mcu.IP0=COMP1
Mcu.IP1=DAC
Mcu.IP10=TIM6
Mcu.IP11=USART2
Mcu.IP2=DMA
Mcu.IP3=I2C1
Mcu.IP4=NVIC
Mcu.IP5=OPAMP1
Mcu.IP6=OPAMP4
Mcu.IP7=RCC
Mcu.IP8=SPI1
Mcu.IP9=SYS
Mcu.IPNb=12
Mcu.Package=LQFP100
Mcu.Pin0=PE2
Mcu.Pin1=PE3
Mcu.Pin10=PA2
Mcu.Pin11=PA3
Mcu.Pin12=PA4
Mcu.Pin13=PA5
Mcu.Pin14=PA6
Mcu.Pin15=PA7
Mcu.Pin16=PC5
Mcu.Pin17=PE8
Mcu.Pin18=PE9
Mcu.Pin19=PE10
Mcu.Pin2=PE4
Mcu.Pin20=PE11
Mcu.Pin21=PE12
Mcu.Pin22=PE13
Mcu.Pin23=PE14
Mcu.Pin24=PE15
Mcu.Pin25=PB12
Mcu.Pin26=PA11
Mcu.Pin27=PA12
Mcu.Pin28=PA13
Mcu.Pin29=PA14
Mcu.Pin3=PE5
Mcu.Pin30=PA15
Mcu.Pin31=PD5
Mcu.Pin32=PB3
Mcu.Pin33=PB6
Mcu.Pin34=PB7
Mcu.Pin35=PE0
Mcu.Pin36=PE1
Mcu.Pin6=PF0-OSC_IN
Mcu.Pin8=PA0
Mcu.Pin9=PA1
Mcu.PinsNb=40
Mcu.ThirdPartyNb=0
Mcu.UserConstants=
PA0.Locked=true
PA1.Mode=INP
PA11.GPIO_Label=DM
PA11.Locked=true
PA11.Signal=USB_DM
PA12.GPIO_Label=DP
PA12.Locked=true
PA12.Signal=USB_DP
PA13.Locked=true
PA14.Locked=true
PA2.Mode=Standalone
PA3.Mode=Standalone
PA5.Locked=true
PA5.Signal=SPI1_SCK
PA6.Locked=true
PA7.Locked=true
PB3.GPIO_Label=SWO
PB3.Locked=true
PB6.Locked=true
PB6.Mode=I2C
PB6.Signal=I2C1_SCL
PB7.Locked=true
PB7.Mode=I2C
PB7.Signal=I2C1_SDA
PC5.Mode=Standalone
PE0.Locked=true
PE0.Signal=GPXTI0
PE1.Locked=true
PE1.Signal=GPXTI1
PE10.Locked=true
PE11.Locked=true
PE12.Locked=true
PE13.Locked=true
PE14.Locked=true
PE15.Locked=true
PE2.Locked=true
PE2.Signal=GPXTI2
PE3.Locked=true
PE4.Locked=true
PE4.Signal=GPXTI4
PE5.Locked=true
PE5.Signal=GPXTI5
PE8.Locked=true
PE9.Locked=true
RCC.FamilyName=M
RCC.LSE_VALUE=32768
RCC.LSI_VALUE=40000
SH.GPXTI0.ConfNb=1
SH.GPXTI1.ConfNb=1
SH.GPXTI2.ConfNb=1
SH.GPXTI4.ConfNb=1
SH.GPXTI5.ConfNb=1
boardIOC=true
‎2024-07-12 8:41 AM - edited ‎2024-07-12 8:42 AM
Libraries should not be changed because people are not using them correctly. You want to use a library, you need to follow its rules. The C include system is a mess, changing this one thing isn't going to fix that. Changing it could make bugs harder to spot.
Agreed, and in the case of the HAL library, that minimal amount of stuff is "stm32f3xx_hal.h".
