STM32f2xx HSI configuration does not work correctly
khodaarahmi
Posted on July 01, 2013 at 13:34
I'm using below settings (in
SystemInit
function) to configure a STM32F215RG MCU to work at maximum speed (120MHZ) with USB support:
 RCC_DeInit(); RCC_HSICmd(ENABLE); while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET); /* Flash 3 wait state, prefetch buffer and cache ON */ FLASH_SetLatency(FLASH_Latency_3); FLASH_PrefetchBufferCmd(ENABLE); FLASH_InstructionCacheCmd(ENABLE); FLASH_DataCacheCmd(ENABLE); /* HCLK = SYSCLK */ RCC_HCLKConfig(RCC_SYSCLK_Div1); /* PCLK2 = HCLK/2 */ RCC_PCLK2Config(RCC_HCLK_Div2); /* PCLK1 = HCLK/4 */ RCC_PCLK1Config(RCC_HCLK_Div4); /* Configure the main PLL clock to 120 MHz */ RCC_PLLConfig(RCC_PLLSource_HSI, PLL_M, PLL_N, PLL_P, PLL_Q); /* Enable the main PLL */ RCC_PLLCmd(ENABLE); /* Wait till the main PLL is ready */ while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); /* Select the main PLL as system clock source */ RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); /* Wait till the main PLL is used as system clock source */ while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
& here are PLL config params:
#define PLL_M 16 #define PLL_N 240 #define PLL_P 2 #define PLL_Q 5
But seems there is a problem with HSI because MCU does NOT start to work after restarting. But when I configure it to use HSE instead (with 8MHZ crystal,
PLL_M=8
) the MCU works as expected. Is there any mistake in my configuration? #stm32f2xx-pll-hsi-config #usb-rcc
4 REPLIES 4
Posted on July 01, 2013 at 14:25
The part boots with HSI running, so the chance it a) doesn't work, and b) needs switching on, are pretty slim.
You should perhaps output clocks via the MCOx pins and check them with a scope.
Also, I don't think HSI is sufficiently accurate for USB usage.
How are you testing that it doesn't work? Do you have some code toggling a GPIO/LED, or something outputting via a USART?
khodaarahmi
Posted on July 01, 2013 at 20:21
I tested it with a toggling LED.
Seems when I modify PLL config params such that set SYSCLK to a value lower than 120MHZ (e.g 60MHZ) it works correctly, but in the user manual I didn't find anything about max CPU frequency limitation while using HSI.
jpeacock2399
Posted on July 01, 2013 at 21:02
USB requires the HSE oscillator:
The USB OTG FS receives the 48 MHz ±0.25% clock from the reset and clock controller
(RCC), via an external quartz. The USB clock is used for driving the 48 MHz domain at fullspeed
(12 Mbit/s) and must be enabled prior to configuring the OTG FS core.
RM0033 rev 4 page 923
Jack Peacock
Posted on July 01, 2013 at 21:49
I don't believe there is, I have F2 boards running at 120 MHz from HSI here.
Have you tried using something close to the original system_stm32f2xx.c with just the PLL_M, and the PLL source changed?
Do you have a debugger that can step into and through SystemInit() ?
