Stm32F103C8X HAL_CAN_Transmit(&hcan,10) not working, always return HAL_TIMEOUT and HAL_ERROR
Dhananjay Khairnar
Posted on March 02, 2017 at 11:56
I am programing STm32F103 for Transmitting CAN data. Initialization of can  is done by following function with 250kb bit rate
static void MX_CAN_Init(void)
      /*♯♯-1- Configure the CAN peripheral ♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯*/
      hcan.Instance = CAN1;
      hcan.pTxMsg = &TxMessage;
      hcan.pRxMsg = &RxMessage;
      hcan.Init.TTCM = DISABLE;
      hcan.Init.ABOM = DISABLE;
      hcan.Init.AWUM = DISABLE;
      hcan.Init.NART = DISABLE;
      hcan.Init.RFLM = DISABLE;
      hcan.Init.TXFP = DISABLE;
      hcan.Init.Mode = CAN_MODE_NORMAL;
      hcan.Init.SJW = CAN_SJW_1TQ;
      hcan.Init.BS1 = CAN_BS1_3TQ;
      hcan.Init.BS2 = CAN_BS2_4TQ;
      hcan.Init.Prescaler = 4;
      if (HAL_CAN_Init(&hcan) != HAL_OK)
        /* Initiliazation Error */
        Error_Handler();
      /*♯♯-2- Configure the CAN Filter ♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯*/
      sFilterConfig.FilterNumber = 0;
      sFilterConfig.FilterMode = CAN_FILTERMODE_IDMASK;
      sFilterConfig.FilterScale = CAN_FILTERSCALE_32BIT;
      sFilterConfig.FilterIdHigh = 0x0000;
      sFilterConfig.FilterIdLow = 0x0000;
      sFilterConfig.FilterMaskIdHigh = 0x0000;
      sFilterConfig.FilterMaskIdLow = 0x0000;
      sFilterConfig.FilterFIFOAssignment = 0;
      sFilterConfig.FilterActivation = ENABLE;
      sFilterConfig.BankNumber = 14;
      if (HAL_CAN_ConfigFilter(&hcan, &sFilterConfig) != HAL_OK)
        /* Filter configuration Error */
        Error_Handler();
      /*♯♯-3- Configure Transmission process ♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯♯*/
            TxMessage.StdId = 0x321;
      TxMessage.ExtId= 0x01;
      TxMessage.RTR = CAN_RTR_DATA;
      TxMessage.IDE = CAN_ID_STD;
      TxMessage.DLC = 2;
      TxMessage.Data[0] = 1;
      TxMessage.Data[1] = 2;
and for transmitting data I used following function is main
while (1)
     int err = HAL_CAN_Transmit(&hcan,10);
      if(err != HAL_OK)
      delay();
err always get HAL_TIMEOUT then after some time HAL_ERROR. I receiving CAN data on Arduino but their is no data on CAN TX. I try to check signals on Oscilloscope its shows fluctuation on first time execution of HAL_CAN_Transmit(&hcan,10).
#can #can-bus #hal_can_transmit #stm32f103c8t6
Dhananjay Khairnar
Posted on March 21, 2017 at 08:37
My problem get solved. It actually I am providing 3.3v power supply to CAN driver which is not up to the working voltage of MCP2551. CAN library is working fine.
1 REPLY 1
Dhananjay Khairnar
