STM32CubeMx 4.8.0 update Firmware FW_F4_V1.6.0
stuk
Posted on June 17, 2015 at 11:19
Hi, i've CubeMx 4.8.0 and i want update the firmware of the STM32F4 board with the new FW_F4_V1.6.0. When i open a project that used fw 1.5.0 i can't understand how can i update to the new 1.6.0 firmware, in the setting of the project its set the 1.5.0 and i can't change it. How can i update to 1.6.0?
#cube #stm32f4 #bug
markb
Posted on June 17, 2015 at 11:42
You can't. This has already been discussed in a previous thread.
stuk
Posted on June 17, 2015 at 13:42
Hi, thanks for reply. Can you post me the link to the thread? I can't find it! Thanks
[EDIT]
Ok, after some research i found the
https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Java/flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Java/Why%20can%27t%20I%20update%20my%20F405%20project%20to%20use%20firmware%6.0&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000F9A0E3A95BA69146A17C2E80209ADC21&currentvi...
But its incredible i've to use an ''hack'' to use the new firmware! Why release newfirmware if CubeMx can't support it? I think when a new firmware version is released, a new version of CubeMx must be released!
