2025-03-04 6:27 AM
STM32CubeG0 git repository points to temporary branch in submodules.
Here the repository cbtl08gp053 is on tag v1.0.1 which is not part of main branch.
2025-03-07 4:36 AM
Hello @hnvseau12,
2025-03-06 3:15 AM
Hello @hnvseau12,
First Thanks for your contribution, you are absolutely right. The repository cbtl08gp053 is on tag v1.0.1, which is not part of the main branch. I speak with GitHub team, and we will fix it soon. Thank you once again for your contribution and for raising this issue.
Rania
2025-03-07 4:36 AM
Hello @hnvseau12,
2025-03-09 11:49 AM
I just published the script that allowed to find the issue, you may use it if that's of any help
