STM32 HAL CAN RX
danfarrelly9
Posted on March 02, 2016 at 13:05
Hello
I am having trouble with the CAN_RX_MSG structure.  As the struct contains both StdId and ExtId fields I have seen incorrect data being received in my ISR when both fields are populated.
if (CAN_RX_MSG.Ext_Id == 0x11111111) { //gather CAN data }
The above statement can evaluate as true when the CAN_RX_MSG structure contains a Std_Id message and its data and leads to the Std_Id data being populated into the program incorrectly.
Can anyone advise as to how I can avoid this issue?  Is the IDE parameter required?
Advice is much appreciated.
Dan
#can #hal #std_id #ext_id
2 REPLIES 2
petr239955
Posted on March 04, 2016 at 16:00
use the IDE,
if  (CAN_RX_MSG.IDE == CAN_ID_EXT)
Petr
danfarrelly9
Posted on March 14, 2016 at 12:42
Thanks very much Petr!
Dan
