[SOLVED] How to make a REST API for the STM32F lwIP?
‎2017-10-13 5:10 AM
I am trying to make a rest api for my stm32f controller. I am using the lwIP library for the Ethernet connection.
I looked at the STMCube applications with the lwIP library, but it works with .(s)html web pages.
i want to make a web interface that can be used for remote IO, settings and reading pins/data.
I want to send the data in JSON strings.The data of LED 1 has to be set my styping into a web browser:
.Does anyone know how to make REST API's for the stm32?
Greetings,
Angus Schmaloer#REST # API #STM32 #lwIP
Ethernet
‎2024-02-15 12:47 AM
Hello i also want to implement RESTAPI. Please can you help me to do so.
‎2024-03-21 7:03 AM
"I want to implement an API for STM32 that allows sending and receiving LORA commands. Could you assist me regarding the API code?
‎2024-03-21 7:21 AM
‎2024-07-25 9:19 AM
I am working on REST API development for a quick prototype. I need your support to implement the same, got stuck
Mani
‎2024-10-13 7:02 PM
Hello, my current project needs to use lwip restful API interface, can you provide a source code and explanation? I would appreciate it.
‎2024-10-20 9:21 PM
Can you share you REST API source Code file
- « Previous
- 1
- 2
- Next »
