2017-03-04 03:21 AM
Everybody,
How can I use SDIO, USB with RTOS ?
I tried initialized RTOS but, SDIO is stopped initializing for some reasons,
Anyone knows ?
Without RTOS, they are working ok.
How to put those functions inside RTOS ?
I tried to understand :
Anyone knows ?
Shall I put test code here :
void MX_FREERTOS_Init(void) {
/* USER CODE BEGIN Init */ /* USER CODE END Init *//* USER CODE BEGIN RTOS_MUTEX */
/* add mutexes, ... */ /* USER CODE END RTOS_MUTEX *//* USER CODE BEGIN RTOS_SEMAPHORES */
/* add semaphores, ... */ /* USER CODE END RTOS_SEMAPHORES *//* USER CODE BEGIN RTOS_TIMERS */
/* start timers, add new ones, ... */ /* USER CODE END RTOS_TIMERS *//* Create the thread(s) */
/* definition and creation of defaultTask */ osThreadDef(defaultTask, StartDefaultTask, osPriorityNormal, 0, 128); defaultTaskHandle = osThreadCreate(osThread(defaultTask), NULL);/* USER CODE BEGIN RTOS_THREADS */
/* add threads, ... */ /* USER CODE END RTOS_THREADS *//* USER CODE BEGIN RTOS_QUEUES */
/* add queues, ... */ /* USER CODE END RTOS_QUEUES */}/* StartDefaultTask function */
void StartDefaultTask(void const * argument){ /* init code for FATFS */ MX_FATFS_Init();/* init code for USB_DEVICE */
MX_USB_DEVICE_Init();/* USER CODE BEGIN StartDefaultTask */
/* Infinite loop */ for(;;) { osDelay(1); } /* USER CODE END StartDefaultTask */}/* USER CODE BEGIN Application */
/* USER CODE END Application */How can I add new task ? and why STM32 suggesting me not using SYSTICK but use TIMER ?
#stm32f1 #sdcard #usb-fs #rtos #sdio2017-03-04 04:05 PM
Is it somewhere here ?
****************************************************************************** * File Name : freertos.c * Description : Code for freertos applications ****************************************************************************** * * Copyright (c) 2017 STMicroelectronics International N.V. * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted, provided that the following conditions are met: * * 1. Redistribution of source code must retain the above copyright notice, * this list of conditions and the following disclaimer. * 2. Redistributions in binary form must reproduce the above copyright notice, * this list of conditions and the following disclaimer in the documentation * and/or other materials provided with the distribution. * 3. Neither the name of STMicroelectronics nor the names of other * contributors to this software may be used to endorse or promote products * derived from this software without specific written permission. * 4. This software, including modifications and/or derivative works of this * software, must execute solely and exclusively on microcontroller or * microprocessor devices manufactured by or for STMicroelectronics. * 5. Redistribution and use of this software other than as permitted under * this license is void and will automatically terminate your rights under * this license. * * THIS SOFTWARE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS 'AS IS' * AND ANY EXPRESS, IMPLIED OR STATUTORY WARRANTIES, INCLUDING, BUT NOT * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A * PARTICULAR PURPOSE AND NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY * RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN NO EVENT * SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. * ****************************************************************************** *//* Includes ------------------------------------------------------------------*/
#include 'FreeRTOS.h'#include 'task.h'#include 'cmsis_os.h'/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Variables -----------------------------------------------------------------*/
osThreadId defaultTaskHandle;/* USER CODE BEGIN Variables */
/* USER CODE END Variables */
/* Function prototypes -------------------------------------------------------*/
void StartDefaultTask(void const * argument);extern void MX_FATFS_Init(void);
extern void MX_USB_DEVICE_Init(void);void MX_FREERTOS_Init(void); /* (MISRA C 2004 rule 8.1) *//* USER CODE BEGIN FunctionPrototypes */
/* USER CODE END FunctionPrototypes */
/* Hook prototypes */
/* Init FreeRTOS */
/* USER CODE END Application *//************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
2017-03-04 06:35 PM
I would start by increasing the stack size in your
osThreadDef to 512 (or higher) and see if that makes a difference. Invariably I have to increase the stack size in the default task when using USB CDC.
I use GCC as my compiler. When I'm in doubt about whether this is a problem, I have GCC dump stack usage statistics (-fstack-usage) for analysis.
Stack usage is what trips me up most when doing RTOS programming.
2017-03-24 04:55 PM
Does it matter with init code if it's outside RTOS ?
Or have conflict between SDIO interrupt and RTOS interrupt ?
