Reset STM32 using BOOT0 and RESET Pins After Bootloader
Options
‎2012-07-04 5:59 AM
Posted on July 04, 2012 at 14:59
I've been working on some Bootloader code recently and with help from this forum have got it working, unfortunately for whatever reason if I reset the Microcontroller (set BOOT0 to 0, and RESET to 0 then 1) and then attempt to go in to Bootloader mode again (set BOOT0 to 1, and RESET to 0 then 1) I cannot get the Bootloader to respond to the intial 0x7F command and it means that I have to do a power cycle instead which is obviously not a great solution.Is there anything really fundamental that I am missing here as it strikes me this should be a relatively problem free thing to do.Thanks in advance for any responses,Dave #bootloader #reset-stm32
Labels:
Bootloader
3 REPLIES 3
Options
‎2012-07-04 6:11 AM
Posted on July 04, 2012 at 15:11
-RESET too short?
- unstable 1 at BOOT0?Options
‎2012-07-04 6:17 AM
Posted on July 04, 2012 at 15:17
Well, it will depend on the specific part.
The 0x7F pattern at 8E1 is not read by the parts, but the width is measured by a timer, and then an appropriate baud rate programmed into the USART. There are dependencies on certain USART pins not changing on parts which scan multiple inputs. That things like the HSI/PLL start. And the state of BOOT1.
Options
‎2013-12-15 7:42 AM
Posted on December 15, 2013 at 16:42
