reset an stm32f746 discovery
‎2024-09-12 1:58 AM
Hi all, on stm32f746 disco, I'm using the Mbed ide but i have the stmcube installed as well
I've been writing a simple updater app that sits at 0x080e0000 with mixed success switching to a previous project, the code downloads but on running the board appears to run the updater code instead. How can I fix this?
I've added an mbed_app.json to both projects with "target.mbed_app_start": "0x08000000"
STM32CubeMX
‎2024-09-13 8:40 AM - edited ‎2024-09-13 8:42 AM
Hello @andy0105 ,
you can use STM32CubeProgrammer to erase the device and reset it to factory settings. Here are the steps to do this:
- Download and Install STM32CubeProgrammer: If you haven't already, download and install STM32CubeProgrammer from the STMicroelectronics website.
- Connect Your Board: Connect your STM32F746 Discovery board to your computer via USB.
- Open STM32CubeProgrammer: Launch the STM32CubeProgrammer application.
- Select the ST-LINK Interface: In the connection settings, select the "ST-LINK" interface and click "Connect".
- Erase the Device :
- Go to the "Erasing & Programming" tab.
- Click on the "Full chip erase" button to erase the entire flash memory of the device
Br
Hello @andy0105 ,
Br
