nucleo-f746zg system memory bootloader, question about pattern 8
EKama.1
Hello there,
I'm trying tu use the system memory bootloader, but the nucleo never enter in this mode. in the AN2606, the note says to use pattern 8 and quotes about boot(pin) and BOOT_ADD0/BOOT_ADD1. I tried put boot pin in high level voltage and restart microcontroller, but the board doesn't enter in bootloader mode. Can you help me about this?
3 REPLIES 3
Guru
How do you know it's not entering the bootloader?
EKama.1
I have connected a conversor usb-ttl to UART1 pinout and trying to send 0x7F and there isn't returns to the terminal.
ABITT.1
have you resolved your problem ?
Why don't you use the Flasher software available on the STM site ?
