Modify usbd_stoge_if.c to use SD Card trougth SPI
‎2021-04-11 10:46 AM
Hi to all,
I managed to interface with the SD card through the SPI and the FaTFS library (thanks to https://01001000.xyz/2020-08-09-Tutorial-STM32CubeIDE-SD-card/) now I need to implement a USB mass storage device on the same hardware.
i don't know how to modify usbd_stoge_if.c tin odero implement the functions:
int8_t STORAGE_GetCapacity_FS(uint8_t lun, uint32_t *block_num, uint16_t *block_size)
int8_t STORAGE_IsReady_FS(uint8_t lun)
Have you any suggestions?
Thanks.
‎2021-05-01 6:08 AM
At the end I was succerfully writed the file.
Here is my usbd_stoge_if.c, writed based on user_diskio_spi.c an user_diskio_spi.h from https://01001000.xyz/2020-08-09-Tutorial-STM32CubeIDE-SD-card/
/* USER CODE BEGIN Header */
* @file : usbd_storage_if.c
* @version : v1.0_Cube
* @brief : Memory management layer.
* @attention
* <h2><center>© Copyright (c) 2021 STMicroelectronics.
* All rights reserved.</center></h2>
* This software component is licensed by ST under Ultimate Liberty license
* SLA0044, the "License"; You may not use this file except in compliance with
* the License. You may obtain a copy of the License at:
* www.st.com/SLA0044
/* USER CODE END Header */
#include "usbd_storage_if.h"
#include "C:\ST\Progetti\Test_USB_2\STM32CubeIDE\Application\User\FATFS\Target\user_diskio_spi.h"
/* USER CODE BEGIN INCLUDE */
/* USER CODE END INCLUDE */
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/** @addtogroup STM32_USB_OTG_DEVICE_LIBRARY
* @brief Usb device.
/** @defgroup USBD_STORAGE
* @brief Usb mass storage device module
/** @defgroup USBD_STORAGE_Private_TypesDefinitions
* @brief Private types.
/* USER CODE BEGIN PRIVATE_TYPES */
/* USER CODE END PRIVATE_TYPES */
/** @defgroup USBD_STORAGE_Private_Defines
* @brief Private defines.
#define STORAGE_LUN_NBR 1
//#define STORAGE_BLK_NBR 0x10000
#define STORAGE_BLK_NBR 0x3AB780
#define STORAGE_BLK_SIZ 0x200
/* USER CODE BEGIN PRIVATE_DEFINES */
/* USER CODE END PRIVATE_DEFINES */
/** @defgroup USBD_STORAGE_Private_Macros
* @brief Private macros.
/* USER CODE BEGIN PRIVATE_MACRO */
/* USER CODE END PRIVATE_MACRO */
/** @defgroup USBD_STORAGE_Private_Variables
* @brief Private variables.
/* USER CODE BEGIN INQUIRY_DATA_FS */
/** USB Mass storage Standard Inquiry Data. */
const int8_t STORAGE_Inquirydata_FS[] = {/* 36 */
/* LUN 0 */
0x00,
0x80,
0x02,
0x02,
(STANDARD_INQUIRY_DATA_LEN - 5),
0x00,
0x00,
0x00,
'S', 'T', 'M', ' ', ' ', ' ', ' ', ' ', /* Manufacturer : 8 bytes */
'P', 'r', 'o', 'd', 'u', 'c', 't', ' ', /* Product : 16 Bytes */
'0', '.', '0' ,'1' /* Version : 4 Bytes */
/* USER CODE END INQUIRY_DATA_FS */
/* USER CODE BEGIN PRIVATE_VARIABLES */
/* USER CODE END PRIVATE_VARIABLES */
/** @defgroup USBD_STORAGE_Exported_Variables
* @brief Public variables.
extern USBD_HandleTypeDef hUsbDeviceFS;
/* USER CODE BEGIN EXPORTED_VARIABLES */
/* USER CODE END EXPORTED_VARIABLES */
/** @defgroup USBD_STORAGE_Private_FunctionPrototypes
* @brief Private functions declaration.
static int8_t STORAGE_Init_FS(uint8_t lun);
static int8_t STORAGE_GetCapacity_FS(uint8_t lun, uint32_t *block_num, uint16_t *block_size);
static int8_t STORAGE_IsReady_FS(uint8_t lun);
static int8_t STORAGE_IsWriteProtected_FS(uint8_t lun);
static int8_t STORAGE_Read_FS(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len);
static int8_t STORAGE_Write_FS(uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len);
static int8_t STORAGE_GetMaxLun_FS(void);
/* USER CODE BEGIN PRIVATE_FUNCTIONS_DECLARATION */
/* USER CODE END PRIVATE_FUNCTIONS_DECLARATION */
USBD_StorageTypeDef USBD_Storage_Interface_fops_FS =
STORAGE_Init_FS,
STORAGE_GetCapacity_FS,
STORAGE_IsReady_FS,
STORAGE_IsWriteProtected_FS,
STORAGE_Read_FS,
STORAGE_Write_FS,
STORAGE_GetMaxLun_FS,
(int8_t *)STORAGE_Inquirydata_FS
/* Private functions ---------------------------------------------------------*/
* @brief Initializes over USB FS IP
* @param lun:
* @retval USBD_OK if all operations are OK else USBD_FAIL
/* USER CODE BEGIN 2 */
USBD_StatusTypeDef ret = USBD_FAIL;
if(USER_SPI_initialize(0) == 0){
ret = USBD_OK;
return ret;//(USBD_OK);
/* USER CODE END 2 */
* @brief .
* @param lun: .
* @param block_num: .
* @param block_size: .
/* USER CODE BEGIN 3 */
//****** TO_DO *********
*block_num = STORAGE_BLK_NBR;
*block_size = STORAGE_BLK_SIZ;
return (USBD_OK);
/* USER CODE END 3 */
* @brief .
* @param lun: .
/* USER CODE BEGIN 4 */
if(USER_SPI_status(0) == 0){
ret = USBD_OK;
return ret;
return (USBD_OK);
/* USER CODE END 4 */
* @brief .
* @param lun: .
/* USER CODE BEGIN 5 */
return (USBD_OK);
/* USER CODE END 5 */
* @brief .
* @param lun: .
/* USER CODE BEGIN 6 */
if(USER_SPI_read(0, buf, blk_addr,blk_len) == 0)
ret = USBD_OK;
return ret;
/* USER CODE END 6 */
* @brief .
* @param lun: .
/* USER CODE BEGIN 7 */
if(USER_SPI_write(0, buf, blk_addr,blk_len) == 0)
ret = USBD_OK;
return ret;
/* USER CODE END 7 */
* @brief .
* @param None
* @retval .
/* USER CODE BEGIN 8 */
return (STORAGE_LUN_NBR - 1);
/* USER CODE END 8 */
/* USER CODE BEGIN PRIVATE_FUNCTIONS_IMPLEMENTATION */
/* USER CODE END PRIVATE_FUNCTIONS_IMPLEMENTATION */
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
Thanks.
‎2021-04-11 1:25 PM
hello
for the capacity question
*block_num = hsd.SdCard.BlockNbr ;
*block_size = hsd.SdCard.BlockSize;
for the second function ,
if device is ready, just return USBD_OK (0)
if not ready , return something else
‎2021-04-11 1:35 PM
HI Vangelis,
hsd working for SDIO implementation, with BSP_SD generated from CUbeM.
I'm searcing for a SPI versione of this function.
‎2021-04-11 1:40 PM
STM32Cube_FW_F4_V1.24.0\Drivers\BSP\Adafruit_Shield\stm32_adafruit_sd.c
STM32Cube_FW_F4_V1.24.0\Drivers\BSP\STM32F4xx-Nucleo\stm32f4xx_nucleo.c
ADAFRUIT_TFT_JOY_SD_ID802
‎2021-05-01 6:08 AM
* @attention
/* LUN 0 */
0x00,
0x80,
0x02,
0x02,
0x00,
0x00,
0x00,
STORAGE_Init_FS,
STORAGE_IsReady_FS,
STORAGE_Read_FS,
STORAGE_Write_FS,
* @param lun:
ret = USBD_OK;
* @brief .
* @param lun: .
return (USBD_OK);
* @brief .
* @param lun: .
ret = USBD_OK;
return ret;
return (USBD_OK);
* @brief .
* @param lun: .
return (USBD_OK);
* @brief .
* @param lun: .
ret = USBD_OK;
return ret;
* @brief .
* @param lun: .
ret = USBD_OK;
return ret;
* @brief .
* @param None
* @retval .
Thanks.
‎2022-12-06 3:32 AM
Thanks for your example! I was able to accomplish a similar task for my project thanks to it.
Best regards,
Phuoc
