August 14, 2019
LL drivers PLL initialization
  • August 14, 2019
  • 4 replies
  • 1247 views
Hi all,
I am experiencing some problem with PLL initialization using LL drivers.
The code I am using for HSE, PLL and SYS clock is the following:
void init_RCC_HSE(void)
	//LL_AHB1_GRP1_EnableClock(LL_AHB1_GRP1_PERIPH_GPIOH);
	LL_RCC_HSE_Enable();
	while(! LL_RCC_HSE_IsReady())
	LL_RCC_HSI_Disable();
	//LL_RCC_HSE_EnableCSS();
	LL_RCC_PLL_Disable();
	LL_RCC_PLL_ConfigDomain_SYS(LL_RCC_PLLSOURCE_HSE, LL_RCC_PLLM_DIV_5, 200, LL_RCC_PLLP_DIV_2);
	LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_1);
	LL_RCC_SetAPB1Prescaler(LL_RCC_APB1_DIV_4);
	LL_RCC_SetAPB2Prescaler(LL_RCC_APB2_DIV_2);
	LL_RCC_PLL_Enable();
	while(!LL_RCC_PLL_IsReady())
	LL_RCC_SetSysClkSource(LL_RCC_SYS_CLKSOURCE_PLL);
	SystemCoreClockUpdate();
But the firmware stops after a few ms.
What is the proper way to initialise it using LL drivers ?
Thanks.
s.
Best answer by Piranha
You haven't told for what MCU this is.
You can't disable HSI, while You are running on it. Switch to PLL, wait for switch to happen and then disable HSI.
Also voltage scale and flash latency must be set accordingly before switching to higher clock rate.
Piranha
PiranhaBest answer
Principal III
August 14, 2019
simo zzAuthor
August 14, 2019
Hello @Piranha​ ,
the MCU is the STM32F407VG.
Of course you are right that HSI must not be disabled before setting other clocks, this is also stated in its TRM.
I modified the function according to your hint.
	LL_PWR_EnableOverDriveMode();
	LL_FLASH_SetLatency(LL_FLASH_LATENCY_5);
	LL_PWR_SetRegulVoltageScaling(LL_PWR_REGU_VOLTAGE_SCALE1);
	while(LL_RCC_GetSysClkSource() != LL_RCC_SYS_CLKSOURCE_STATUS_PLL)
Thanks.
s.
Piranha
Principal III
August 25, 2019
When switching to higher frequency, all bus dividers (including APB1 and APB2) must be updated before switching like it was in the first code version.
Also consider enabling prefetch and instruction/data caches in FLASH_ACR to maximize performance.
simo zzAuthor
September 9, 2019
Thank you @Piranha​ for your suggestions.
Cheers.
s.
