Is it possible to connect the stm32f107** directly to the wifi-module via the Ethernet interface to increase the data rated speed?
Options
‎2018-10-08 5:54 AM
Options
‎2018-10-08 6:17 AM
What do you mean, "directly" ?
If you use Ethernet, you will still need the usual Ethernet magnetics, PHY, etc.
When you say, "increase the data rated speed" - relative to what?
Options
‎2018-10-08 6:44 AM
I was assigned the task "Connect the WiFi-module to the STM32 via the Ethernet interface". I want to know if this will work correctly?
Regarding the data transfer rate, I meant that Ethernet allows you to have high speed relative to other interfaces.
