Incomprehensible behavior with the LWIP library.
valik mahrov
Recently I switched to STM32F767ZI using LAN8742A and the LWIP library. Began to develop a web configurator based on this STM. And there is such a problem. 0690X000008j6C9QAI.png
where 192.168.97.200 is a device, 192.168.97.1 is a client (computer).
During data transfer to get, the request goes to a packet with the SYN flag, after which the device does not transmit data, does not respond to ping.
The code is presented below.
char *buf;
struct http_state
  char *file;
  u32_t left;
static void
conn_err(void *arg, err_t err)
  struct http_state *hs;
  hs = arg;
  mem_free(hs);
static void
close_conn(struct tcp_pcb *pcb, struct http_state *hs)
  tcp_arg(pcb, NULL);
  tcp_sent(pcb, NULL);
  tcp_recv(pcb, NULL);
  mem_free(hs);
  tcp_close(pcb);
static void
send_data(struct tcp_pcb *pcb, struct http_state *hs)
  err_t err;
  u16_t len;
  /* We cannot send more data than space avaliable in the send
     buffer. */
  if (tcp_sndbuf(pcb) < hs->left)
    len = tcp_sndbuf(pcb);
  else
    len = hs->left;
  err = tcp_write(pcb, hs->file, len, 0);
  if (err == ERR_OK)
    hs->file += len;
    hs->left -= len;
static err_t
http_poll(void *arg, struct tcp_pcb *pcb)
  if (arg == NULL)
    /*    printf("Null, close\n");*/
    tcp_close(pcb);
  else
    send_data(pcb, (struct http_state *)arg);
  return ERR_OK;
static err_t
http_sent(void *arg, struct tcp_pcb *pcb, u16_t len)
  hs = arg;
  if (hs->left > 0)
    send_data(pcb, hs);
  else
    close_conn(pcb, hs);
  return ERR_OK;
static err_t
http_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err)
  int i, j;
  char *buf;
  hs = arg;
  if (err == ERR_OK && p != NULL)
    /* Inform TCP that we have taken the data. */
    tcp_recved(pcb, p->tot_len);
    if (hs->file == NULL)
       //handler
else
      pbuf_free(p);
  return ERR_OK;
static err_t
http_accept(void *arg, struct tcp_pcb *pcb, err_t err)
  /* Allocate memory for the structure that holds the state of the
     connection. */
  hs = mem_malloc(sizeof(struct http_state));
  if (hs == NULL)
    return ERR_MEM;
  /* Initialize the structure. */
  hs->file = NULL;
  hs->left = 0;
  /* Tell TCP that this is the structure we wish to be passed for our
     callbacks. */
  tcp_arg(pcb, hs);
  /* Tell TCP that we wish to be informed of incoming data by a call
     to the http_recv() function. */
  tcp_recv(pcb, http_recv);
  tcp_err(pcb, conn_err);
  tcp_poll(pcb, http_poll, 10);
  return ERR_OK;
void
httpd_init1(void)
  struct tcp_pcb *pcb;
  pcb = tcp_new();
  tcp_bind(pcb, IP_ADDR_ANY, 80);
  pcb = tcp_listen(pcb);
  tcp_accept(pcb, http_accept);
Who knows what the problem is? Thank you in advance. (I want to add that I'm doing a multiplayer web configurator.)
1 REPLY 1
valik mahrov
Here is a file to make my problem easier to understand. The problem begins with the package number 62733.
