how to read key F1, F2..... from keyboard with stm32f4-- I did it. file Keyboard_done
nguen nguyen
Posted on May 01, 2018 at 12:45
stm32f411 disco. connect with keyboard via USB
uint8_t GetKey(void)
uint32_t c;
if(Appli_state==APPLICATION_START)
if(USBH_HID_GetDeviceType(&hUsbHostFS) == HID_KEYBOARD)
k_pinfo = USBH_HID_GetKeybdInfo(&hUsbHostFS);
if(k_pinfo != NULL)
c = USBH_HID_GetASCIICode(k_pinfo);
return c;
while (1)
/* USER CODE END WHILE */
MX_USB_HOST_Process();
/* USER CODE BEGIN 3 */
d=GetKey();
if (d == '1' ) HAL_GPIO_WritePin(GPIOD, GPIO_PIN_13, GPIO_PIN_SET);
if (d == '2') HAL_GPIO_WritePin(GPIOD, GPIO_PIN_13, GPIO_PIN_RESET);
#stm32 #usb_host
4 REPLIES 4
Pavel A.
Evangelist III
Posted on May 02, 2018 at 01:16
These keys do not map to plain ASCII characters. So revise the keyboard report translation in GetKey() and do something else (return 16-bit or 32-bit values for example).
-- pa
Posted on May 02, 2018 at 03:05
Thanks, you know what exactly function I need to use to read function key(F1, F2...)
Posted on May 03, 2018 at 02:49
Look into functions
USBH_HID_KeybdDecode ,
in .../Middlewares/ST/STM32_USB_Host_Library/Class/HID/Src/usbh_hid_keybd.c
-- pa
Posted on May 03, 2018 at 07:49
I did it ----------�?£Ñ€�?°�?°�?°�?°
//c = USBH_HID_GetASCIICode(k_pinfo);    //get ASCII code
c=k_pinfo->keys[0];
 //get scancode
