You get the MCU in bootloader mode (with boot 0 and reset, or however you want)
Make sure you have connected your uart adapter to the correct pins (see AN2606 and your device's datasheet/reference manual, I don't remember which one)
Make sure you read AN2606 for setting uart parameters in the next step
Start stm32cubeprogrammer, select uart, fill the parameters, select the correct COM port
