HAL_UART_Receive_IT usage
Alexmouse
I'm having trouble understanding correct usage of the HAL UART functions to receive incoming bytes. The function assumes you know the byte count in advance. I would expect a receive function to respond to receive buffer full,empty and maybe half full flags? How to use the UART HAL layer functions to receive indeterminate incoming data?
S.Ma
Principal
Save time: for USART, use low layer (LL).
Alexmouse
Makes a bit of a mockery of the HAL layer, but I suspect you're right.
