HAL H7xx Library ll_utils.c Warning
‎2023-02-16 10:41 AM
stm32h7xx_ll_utils.c throws a warning "no LL_RCC_CalcPLLClockFreq" function at line 930. The function exists in stm32h7xx_ll_rcc.c but has a conditional compile USE_FULL_LL_Driver.
Calls to conditional compiles should be under the same conditional conditions.
Cheers, Hal
STM32Cube MCU Packages
STM32H7 Series
‎2023-02-27 1:17 AM
Hello @raptorhal2​ ,
Thank you for bringing these issues to our attention.
I confirm and I reported Internally.
Firmware related issue tracked under the number 146496.
This is an internal tracking number and is not accessible or usable by customers.
Patrice
‎2023-02-17 8:03 AM
Hello @raptorhal2​
Please check you are using the latest version of CubeH7 firmware.
You may check this report
‎2023-02-17 8:21 AM
I am using the latest, 1.11.0 dated 15 November 2022.
‎2023-02-18 1:33 PM
Such a trivial issue and a year later absolutely nothing has been done. Good job!
‎2023-02-18 4:43 PM
So what's the problem? Just define USE_FULL_LL_DRIVER. Any unused functions will be removed by the linker.
‎2023-02-18 5:38 PM
->Just define USE_FULL_LL_DRIVER. Any unused functions will be removed by the linker.
Very true. And since it a warning, subsequent Builds (but not Rebuilds) will not raise the warning. But I am asking for some code discipline.
Cheers, Hal
‎2023-02-27 1:17 AM
Patrice
