HAL_Delay() not working.. help (newbie)
‎2015-12-03 4:51 PM
I tried using HAL_Delay(); I thought I can just use HAL_Delay(500); but it's not working.the code is below. (from STM32cubeF4)__weak void HAL_Delay(__IO uint32_t Delay){ uint32_t tickstart = 0; tickstart = HAL_GetTick(); while((HAL_GetTick() - tickstart) < Delay) { }}I found the first time tickstart = HAL_GetTick() is performed, the tickstart has the value 0. The second time, HAL_GetTick() returns some big value so it stays endlessly in while statement.Is there something I should do before using HAL_Delay()? #hal_delay- Labels:
STM32Cube MCU Packages
‎2015-12-03 5:32 PM
Some big number minus zero is presumably bigger than 500? That would presumably exit the loop, so I'm confused. SysTick, with it's handler, must be functional for HAL_Delay() to work.
‎2015-12-04 5:31 AM
[DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Discovery/Flat.aspx?RootFolder=/public/STe2ecommunities/mcu/Lists/STM32Discovery/uwTick%20not%20incrementing.%20%28HAL_Delay%28%29%29&FolderCTID=0x01200200770978C69A1141439FE559EB459D75800084C20D8867EAD444A5987D47BE638E0F&TopicsView=https://my.st.com/public/STe2ecommunities/mcu/Lists/STM32Discovery/AllItems.aspx¤tviews=9]Duplicate thread
Isn't the SysTick enabled/configured in HAL_Init() or something? And with handler code?/**
* @brief This function handles SysTick Handler.
* @param None
* @retval None
void SysTick_Handler(void)
HAL_IncTick();
‎2015-12-04 6:38 AM
