FATFS: show all files
mfrank9
is it possibility to show a list of files and folders with the fatfs library?
Like "ls" in the console.
The FatFs library provides you with the means to implement this, but not the code, although you might find some if you look.
Typically a problem that can be solved via recursive, or queued linear, traversal
For a simple single level
puts("Display Directory");
    DIR dir;
    char *path;
    UINT BytesWritten;
    char string[128];
    path = ""; // where you want to list
    res = f_opendir(&dir, path);
#ifdef DBG
    if (res != FR_OK)
      printf("res = %d f_opendir\n", res);
#endif
    if (res == FR_OK)
      while(1)
        FILINFO fno;
        res = f_readdir(&dir, &fno);
#ifdef DBG
        if (res != FR_OK)
          printf("res = %d f_readdir\n", res);
#endif
        if ((res != FR_OK) || (fno.fname[0] == 0))
          break;
        sprintf(string, "%c%c%c%c %10d %s/%s",
          ((fno.fattrib & AM_DIR) ? 'D' : '-'),
          ((fno.fattrib & AM_RDO) ? 'R' : '-'),
          ((fno.fattrib & AM_SYS) ? 'S' : '-'),
          ((fno.fattrib & AM_HID) ? 'H' : '-'),
          (int)fno.fsize, path, fno.fname);
        puts(string);
4 REPLIES 4
SBEN .2
Senior II
Hello @mfrank9​ ,
It is possible to recursively travers the file tree using FATFS and display its content using f_readdir(). A limited example, for inspiration, can be found in the implementation of kStorage_GetDirectoryFiles() (See here) in the STM32G474E-EVAL demonstration project.
Best regards,
@SBEN .2​
    DIR dir;
    char *path;
    UINT BytesWritten;
    char string[128];
#ifdef DBG
    if (res != FR_OK)
#endif
    if (res == FR_OK)
      while(1)
        FILINFO fno;
#ifdef DBG
        if (res != FR_OK)
#endif
          break;
        puts(string);
mfrank9
Thank you!
That works.
The following lines don't do what they're supposed to, but I don't know why.
This is not a problem as they work when called individually.
TBode.1
Thanks!
Helped me much.
