failing to generate a random number using stm32f4xx_rng
‎2016-11-10 8:34 AM
Hi all,
I am using an stm32f4 micro to generate a random number. I am using the RNG Driver from the stm32cubef4 library. I followed the examples but the micro is generating the same number over and over again. here is a code snippet.
int
main(
void
HAL_Init();
system_init();
if
(HAL_RNG_Init(&hRNG1) != HAL_OK)
DEBUG_PRINT(
''Random Number generation failed\r''
if
(HAL_RNG_GenerateRandomNumber(&hRNG1,code_)==HAL_OK)
DEBUG_PRINT(
''RNG initiated\r''
else
DEBUG_PRINT(
''RNG failed\r''
DEBUG_PRINT(
PRIu32
''\r''
,code_[0]);
Does anybody have a clue on what am missing. I am using the DEBUG_PRINT function to get the random value through the serial port.
Best Regards
Raiyan
#no-hablo-hal #stm32f407-random-number-generate
STM32Cube MCU Packages
STM32F4 Series
‎2016-11-14 3:01 AM
Hi clive1,
I finally managed to solve the issue. What I was missing from the code is the instance initiation and a correct PLL clock initiationRNG_HandleTypeDef hRNG1;
int
main()
hRNG1.Instance = RNG;
and also I might have not configured my PLL correctly. Now I configured it as follow
/*Enable HSE Oscillator and activate PLL with HSE as source*/
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLM = 25;
RCC_OscInitStruct.PLL.PLLN = 336;
RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
RCC_OscInitStruct.PLL.PLLQ = 7;
HAL_RCC_OscConfig(&RCC_OscInitStruct);
/* Select PLL as system clock source and configure the HCLK, PCLK1 and PCLK2
clocks dividers*/
RCC_ClkInitStruct.ClockType = (RCC_CLOCKTYPE_SYSCLK | RCC_CLOCKTYPE_HCLK | RCC_CLOCKTYPE_PCLK1 | RCC_CLOCKTYPE_PCLK2);
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5);
Thanks a lot for your help
Regards from Austria,
‎2016-11-10 11:18 AM
What does it actually output?
The RNG must have its AHB clock enabled, and the PLL Q must be clocking and outputting 48MHz. Things won't work if the PLL isn't running.Review the Reference Manual, examine the registers and settings directly.Up vote any posts that you find helpful, it shows what's working..
‎2016-11-10 11:21 AM
Don't exit main()
Provide output fromwhile(1)
DEBUG_PRINT(''%'' PRIu32 ''
'',code_[0]);
HAL_RNG_GenerateRandomNumber(&hRNG1,code_);
‎2016-11-11 1:56 AM
‎2016-11-11 8:20 AM
Does this work?
code_[0] = 12345;
'',code_[0]);
I might examine the RNG hardware on the F4 under the SPL if I get time. You should review the Reference Manual, and output/advance the registers manually.
‎2016-11-11 12:07 PM
Interestingly the STM32F446ZE doesn't have an RNG
On the STM32F429ZI I had more joyvoid RNG_Configuration(void)
/* Enable RNG clock source */
RCC_AHB2PeriphClockCmd(RCC_AHB2Periph_RNG, ENABLE);
/* RNG Peripheral enable */
RNG_Cmd(ENABLE);
RNG_Configuration();
printf(''%10lu
'', RNG_GetRandomNumber());
printf(''%10lu
printf(''%10lu
printf(''%10lu
1820376166
544183808
417758785
2790747703
‎2016-11-14 3:01 AM
Hi clive1,
int
main()
clocks dividers*/
