Ethernet works smoothly but after addition of small code it does not give ping response.
‎2022-01-06 11:22 PM
I am using STM32F429ZI Freertos+TCPIP+TFTP . Ethernet works smoothly but after addition of small code which includes some global array of 2KB it does not give ping response. when I uncomment the global array then again it works properly. What is the reason. I have suffiecient Free SRAM Memory. Till Now SRAM Usage is 57%.
- Labels:
Ethernet
FreeRTOS
STM32F4 Series
‎2022-01-07 12:41 AM
What ram region are you creating your array in? TCM and ethernet cannot be used together.
‎2022-01-07 1:43 AM
We are not using TCM. The array is declared globally. So it is in .bss section of SRAM.
Thanks,
Anagha
‎2022-01-07 2:13 AM
Your description is??? which includes some global .... when I uncomment the global array
and showing code can help you no this ...
And my glass ball say you use array that isnt volatile on unblocking func...
