Error on stm32h750 svd file in section DFSDM
dos106
I have found a mistakes on stm32h750 svd file in section DFSDM. Many of registers have other address as real. Is possible to obtain svd file with right addresses? Thank you.
4 REPLIES 4
dos106
I repair the svd xml file. Now is the debug in Keil OK. If somebody need it, please, write me message.
Imen.D
Hello @dos106​ ,
We raised this issue internally to fix all STM32H7 SVD files in the coming release.
Please find attached the updated STM32H750x.svd file.
Thanks for you contribution and for highlighting this issue.
Best Regards,
Imen
Imen
Hi, I am wondering when this change will be implemented? I am currently working with the STM32H743 series and this has the same problem with the svd file regarding the DFSDM​
dos106
I use the DFP version 2.5.0 and the SVD file is the same as from Imen.
