Error in LwIP. implicit declaration of function 'gethostbyname'; did you mean 'getsockname'?
Kevin(Dr.Electron)
I tried to port the X-CUBE-IOTA1 Lib to the STM32F7-Disco.
So i startet with a void Project added the Cube Iota files and enabled the LwIP Module.
But in the http_manager.c file all gethostbyname calls throw the above error.
I don't understand how the compiler can't find the function.
All Files should be included correctly.
Do i have to change some LwIP Settings?
I know that may be a dump question, but i can't find the error.
If you need some Code let me know.
Thanks for your Help,
Kevin
Antonio Vilei
Senior III
Hi Kevin,
did you solve your problem? If you still have issues, please let us know.
Best regards,
Antonio
Yes, problem solved.
Thanks for your answer.
