Error in LwIP. implicit declaration of function 'gethostbyname'; did you mean 'getsockname'?
‎2019-11-19 12:58 PM
I tried to port the X-CUBE-IOTA1 Lib to the STM32F7-Disco.
So i startet with a void Project added the Cube Iota files and enabled the LwIP Module.
But in the http_manager.c file all gethostbyname calls throw the above error.
I don't understand how the compiler can't find the function.
All Files should be included correctly.
Do i have to change some LwIP Settings?
I know that may be a dump question, but i can't find the error.
If you need some Code let me know.
Thanks for your Help,
Kevin
‎2020-10-13 1:20 AM
Hi Kevin,
did you solve your problem? If you still have issues, please let us know.
Best regards,
Antonio
‎2020-10-13 1:54 AM
Yes, problem solved.
Thanks for your answer.
