Does anyone know of an example showing SPI implemented with DMA on freeRTOS? I was not able to get this running. When I check the data variable in DMA2_Stream0_IRQHandler, it is always 0 when I expect it to be 1.
I'm using the STM32F407G DISCO.
‎2023-05-29 5:15 PM
I have SPI set in Master Receive Mode Only and my code does work when not passing data to DMA.
DMA
FreeRTOS
SPI
STM32F4 Series
‎2023-05-30 4:34 AM
Hello @LMorr.3​,
Have you checked the CubeFW example of SPI data buffer transmission and reception with DMA?
It's not with freeRTOS though
‎2023-05-30 4:56 AM
Thanks, I'm looking at that sample code now. One issue is that I'm not clear on what libraries I should be using. HAL libraries are discouraged, which leave me with bare-metal. I wish someone would just post a simple explanation on how CMSISV1, CMSISV2, HAL, LL, and all the other 'libraries' work together and which ones are deprecated. Seems like a very messy approach grown over the years by folks who are way to deep to get a new-comer's eye view on getting setup. All official docs recommend HAL but then sample code now shows library usage I've not come across yet ( LL_ ) so I'll have to learn about that before I can proceed. Still not sure if I should now focus on coding with LL instead of bare metal, CMSIS or HAL.
‎2023-05-30 7:38 AM
To partly answer my own questions: HAL does not seem to support DMA for Master receive only mode. Its functions expect DMA to be setup for tx as well or exits with HAL_ERROR. Will look at using CMSIS to see if that helps.
Also, I think LL is no longer supported.
‎2023-05-30 1:20 PM
UPDATE:
I always see hdmarx status 'HAL_DMA_STATE_ABORT' in DMA2_Stream0_IRQHandler each time I call HAL_SPI_Receive_DMA(hspi,pData, Size)
Not sure what would cause that.
‎2023-06-01 2:23 PM
I am all set now, thanks!
