display Assertion "pbuf_free: p->ref >0" failed at line 747... and stop ethernet commnunication aperiodically.
YPARK.14
​I use stm32h743 with lwip. tcp and udp work fine respectively. but, Running tcp and udp at the same time breaks the communication aperiodically, and display Assertion "pbuf_free: p->ref >0" failed at line 747... stm32cubeH7 example is the same. but stm32F7 is good working without problem. I think stm32cubeH7 example is flawed.
Piranha
Chief II
With ST's code networking is virtually impossible, especially on H7. Fixing their code requires more effort than writing normal ETH driver and integrating lwIP on your own.
https://community.st.com/s/question/0D50X0000BOtfhnSQB/how-to-make-ethernet-and-lwip-working-on-stm32
Sankar
hi, i am also facing similar problem. did you get the solution? could you help ?
hi,did you get the solution?
