Combine 2 USB Descriptors
Radoslav Malinov
Posted on March 07, 2018 at 15:11
Hello friends!
I'm noob with STM32F103C8T6 boards and Keil uVision5 but somehow i manage to make simple projects...
 Now im trying to make a Joystic with Serial Input Output to display information on LCD but i cant combine 2 USB descriptors so to use Joystic and Serial over the USB
 I only can make them work separately but not combined.
My questions is:  Is it possible, and if so can someone helps me with some info and basic example to understand the basics of combining 2 different USB descriptors?
Thanks!
#custom-descriptor-usb #2-usb-descriptors #stm32f103c8t6 #usb-hid
Pavel A.
Evangelist III
Posted on March 07, 2018 at 15:16
This is called 'USB composite device'.  The ST libraries and samples do not currently support this, but Segger library does (maybe Keil's does too).
-- pa
Posted on March 07, 2018 at 15:29
Thanks my friend i will search some info about
Segger library and i will try to use it.
