2024-11-19 02:57 AM
Hello ST Community,
I am currently working on a project using the STM32U5G9ZJT6Q MCU. My application involves sending data over USB using CDC-ACM mode.
While the code appears to be working correctly, I am encountering an issue where the execution gets stuck in the scheduler.
However, during runtime, the code halts, and the debugger points to _tx_thread_schedule();
I suspect there might be an issue with middleware integration or clock settings, but I am unable to pinpoint the root cause.
The code I am using is sourced from this link:
Has anyone encountered a similar issue or have any insights into what could be causing this? Any guidance or suggestions for debugging would be greatly appreciated.
Thank you in advance for your support!
